the goal in the end is to replicate the lot in several areas to estimate the number of accommodation buildings and consequently the number of people that can stay in this places.
I have several measures for the typical block, such as: the road width, the parking between the road and the front of building, the building width and length, and the distance between the lot limit and building in both sides and back.
The examples that I have seen divide the block in parcels in a random way. I prefer with those measures, is it possible?
and if so could I run some report that projects the number of people that could stay if those buildings are built?
I start to write this rule file.... but I am novice, and maybe this is not the path for what I want... any suggestion is welcome.
cheers
P
@Start Rule
Block-->
Outer
Building
Outer-->
extrude(0)
comp(f) {front : Bld_front | back : Bld_back | left : Bld_sides | right : Bld_sides | top : roof}
Sides-->
Offset (-6.5)
Bld_front-->
Offset (-11.6)
Bld_back
offset (-4.3)
Building
