<layer> <token/> <definitionexpression/> <enableexport>true</enableexport> <name>BDMT</name> <url> xyz /rest/services/WMAS/BDMT3WMAS/MapServer/0</url> <expressions> <expression alias="dossier number" textsearchlabel="Search by # dossier" > <values> <value prompt="Exemple: 3366114 or 3366" isvaluerequired="true">#Dossier LIKE '%[value]%'</value> </values> </expression> <expression alias="MRC" textsearchlabel="Search by MRC:" isvaluerequired="true"> <values> <value prompt="Exemple: " isvaluerequired="true" uniquevalsfromfield="MRC" autosubmit="true">MRC = '[value]'</value> </values> </expression> <expression alias="Municipalite" textsearchlabel="Recherche par Municipalite:" isvaluerequired="true"> <values> <value prompt="Exemple: Nicolet" isvaluerequired="true" uniquevalsfromfield="Municipalite" autosubmit="true">Municipalite = '[value]'</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Zoning</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>#Dossier</titlefield> <fields all="false"> <field name="#Dossier"/> <field name="dossier_id" alias="ID Dossier" visible="true" gridfield="true"/> <field name="Municipalite" alias="Municipalité" visible="true" gridfield="true"/> <field name="MRC" alias="MRC" visible="true" gridfield="true"/> </fields> <links/> <zoomscale usegeometry="true" zoompercent="2"></zoomscale> <autoopendatagrid>true</autoopendatagrid> <queryattachments>false</queryattachments> </layer>
I do have an autogenerated number (unique values, required=true) field on my table, this way, Arc will use that in leiu of an OID field. R_
Thank you Rhett for your helpYour related Technical Articles is for ArcGIS under 10.0. Is it still up to date?Thank you so much for your time.Alex
I could never get the full functionality out of an event theme until I had the properties in ArcMap show that it has an OID field
