Hi,I'm new to python (and programming in general), in a script I want to loop through a feature class, use a geoprocessing tool on each row, and access the area of the new (temporary features) created by the tool. On the help pages for the geometry object, it states that a blank object can be created for temporary output, for example:workspace = ".../file.gdb"
testShape = ".../test_graphics"
dBufDis = -10
g = arcpy.Geometry()
geometryList = arcpy.Buffer_analysis(testShape, g, dBufDis)
for geometry in geometryList:
print geometry.area
The above works on my test shape and I get a list of areas of the new buffers, however, I want to put the geoprocessing tool into a loop something like this: rows = arcpy.SearchCursor(testShape)
for row in rows:
rowShape = row.getValue(shapeName)
arcpy.Buffer_analysis(rowShape, g, dBufDis)
and then access the area for each row, but this is where I can't seem to get to the area property of the temporary geoprocessing output. Why doesn't "g.area" return the area? If .area is a property of the geometry object? Hasn't g been "populated" by the output of the processing tool for each row?Thanks for any help.
