I am trying to create a grid inside polygon. I applied a fishnet solution. Nevertheless, when I run the code the polygon is expanding (see attached photos). Could you point me what I am doing wrong? I am using the code that I have found in one of discussions. I have changed many things, but maybe I have omitted something important. Many thanks for help!
class NetButton(object):
"""Implementation for NetButton.button (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
in_polys= ExcavationZone #established earlier as global
out_loc= "\\\\abc\\home\\xyz\\Documents\\moje dokumenty\\xyz\\arcgis" #final grid
cell_x= 0
cell_y= 0
n_rows= 30
n_cols= 30
# Create file gdb to store data
gdb = str(arcpy.CreateFileGDB_management(out_loc, 'Fishnets.gdb').getOutput(0))
# spatial reference
arcpy.env.outputCoordinateSystem = arcpy.Describe(in_polys).spatialReference
# Loop thru rows of input polygons
with arcpy.da.SearchCursor(in_polys, ['SHAPE@', 'OID@']) as rows:
for row in rows:
ext = row[0].extent
st = '%f %f' %(ext.XMin, ext.YMin)
orien = '%f %f' %(ext.XMin, ext.YMax)
# Create fishnet
out = os.path.join(gdb, 'fish_{0}'.format(row[1]))
arcpy.CreateFishnet_management(out, st, orien, cell_x,
cell_y, n_rows, n_cols,
labels='NO_LABELS',
geometry_type='POLYGON')
# set workspace to new gdb
arcpy.env.workspace = gdb
fishnets = arcpy.ListFeatureClasses()
targ = fishnets[0]
for i, fish in enumerate(fishnets):
# Add field for original polygon ID
fid = fish.split('_')[1]
arcpy.AddField_management(fish, 'POLY_ID', 'LONG')
with arcpy.da.UpdateCursor(fish, ['POLY_ID']) as rows:
for row in rows:
row[0] = fid
rows.updateRow(row)
# append fishnets into one feature class
if i > 0:
arcpy.Append_management([fish], targ, 'NO_TEST')
arcpy.Delete_management(fish)
print 'Appended: {0}'.format(fish)
print 'Done'
return
if __name__ == '__main__':
polys = "\\\\abc\\home\\xyz\\Documents\\moje dokumenty\\abc\\arcgis\\PolygonGrid"
loc = "\\\\abc\\home\\xyz\\Documents\\moje dokumenty\\abc\\arcgis"
CreateFishnetsForFeats(polys, loc, 100, 100, 22, 22)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
