I am trying to Package a Project in ArcGIS Pro. The Analyze tick appears with no errors. Then when I try to package it, I get ERROR 001795: Failed to consolidate project due to problem with Geoprocessing History item: Copy Features. I removed the Copy Features from the Geoprocessing History but the error persists. Does anyone have a solution for this problem?
Does your Pro project contain a model? And if so, are you using the Make Feature Layer command in the model as well? Another thing to check - are you using tasks at all? Pls advise.
Error 1795 may appear if an item in your Geoprocessing History has an error and cannot be packaged. To resolve the issue, go to the Project Pane > Geoprocessing History and remove any items with errors.
Hi Yvonne,
I had the same problem. I could solve only by deleting all the GP history.
Don't know whether is the solution but at least I could package.
