I am using a popup in a side panel. It is a tabContainer. I have a details tab which I am writing the content to, works great.I would like a LINK panel, which contains a number of hyperlinks for each popup item.How do i attach the hyperlinks to the content? Right now I have a JSON Array of hyperlinks that is generated at the same time as my popup content.psuedo code
//start loop for each feature
//how do i put these in the popup so i can access them later?
var links = [{link1: 'http://...", link2: 'http://....'}]
//popup content
var fieldInfos= [];
dojo.forEach(fieldNames, function(name){
fieldInfos.push({
fieldName: name, visible:true
// alert(fieldInfos);
var g = new esri.Graphic(f.geometry, sym, attrs);
g.setInfoTemplate (new esri.dijit.PopupTemplate({
title: title,
fieldInfos: fieldInfos
map.graphics.add(g);
features.push(g);
//end loop
this.popup.setFeatures(features);
this.popup.select(0);
