I am having a problem hyperlinking documents to an attribute table. Based on what i was able to tell it should be a fairly straight forward process where you select the hyperlink button and drill down to the file location to find the document to be hyperlinked but that does not work. In stead i am having to type in the individual file location into the hyperlinked field in the attribute table......any suggestions as to what i may be doing wrong?
Have you thought about using attachments instead?
PS
Not too many people in GeoNet Lounge interested ... maybe you might want to move it to Geoprocessing or some other place... GeoNet Community Structure
Using Hyperlinks—Help | ArcGIS for Desktop
Maybe you didn't want field based hyperlinks then. I would chose the type to match your desired workflow
