Basically I am trying to duplicate the Google Maps, Picasa images layer... in an arcgis javascript applicationHere's an example of it working in Google maps... http://geology.utah.gov/testing/fieldtrip/index.html (it is dynamically pulling a Picasa feed of thousands of images, and then clustering them on the google map, using the top picture in the stack as the cluster marker symbol.)[ATTACH=CONFIG]15923[/ATTACH]Using the new point clustering class (http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layers_point_clustering.html) I'v pretty much got it working in the arcgis javascript api.... I just need to replace the default renderer picture marker symbol with a dynamic image from the attributes of the marker on the top of the markercluster stack.Any Ideas? Here's my ArcGIS application so far... http://geology.utah.gov/testing/fieldtrip/esrimap_1.htmlThe code that manages the marker symbols looks like this function addClusters(response) {
var photoInfo = {};
var wgs = new esri.SpatialReference({ "wkid": 4326 });
//photoInfo.data = dojo.map(resp, function(p) {
photoInfo.data = dojo.map(response.feed.entry, function(p) {
try {
var pos = p["georss$where"]["gml$Point"]["gml$pos"]["$t"] ;
var lat = pos.substr(0,pos.search(" "));
var lng = pos.substr(pos.search(" "));
} catch (e) {
//console.log("not there: "+e.message);
var latlng = new esri.geometry.Point(parseFloat(lng), parseFloat(lat), wgs);
var webMercator = esri.geometry.geographicToWebMercator(latlng);
var attributes = {
"Caption": p.summary["$t"],
"Title": p.title["$t"],
"NumberComments": p.gphoto$commentCount["$t"],
"Tags": p["media$group"]["media$keywords"]["$t"],
"Name": "none",
"Image": p["media$group"]["media$thumbnail"][4].url,
"Link": p.link[1].href
//console.log(attributes);
return { "x": webMercator.x, "y": webMercator.y, "attributes": attributes };
// popupTemplate to work with attributes specific to this dataset
var popupTemplate = esri.dijit.PopupTemplate({
"title": "Virtual Field Guide",
"description":'<div class="popupDiv">' +
'<div class="popupImage"><a href="{Link}" target="_blank"><img src="{Image}" ></a></div>' +
'<br><span class="popupField">File Name: </span> <span class="popupValue">{Title} </span>' +
'<br><span class="popupField">Tags: </span> <span class="popupValue">{Tags} </span>' +
'<br><span class="popupField">Caption: </span> <span class="popupValue">{Caption} </span>' +
'<br><span class="popupField">User Comments: </span> <span class="popupValue">{NumberComments} </span>' +
'<br><small><a href="{Link}" target="_blank"> Open in Picasa </a></small>' +
'</div>'
// cluster layer that uses OpenLayers style clustering
clusterLayer = new extras.ClusterLayer({
"data": photoInfo.data,
"distance": 30,
"id": "clusters",
"labelColor": "#fff",
"labelOffset": 0,
"resolution": map.extent.getWidth() / map.width,
"singleColor": "#888",
"showSingles": true,
"singleTemplate": popupTemplate
var defaultSym = new esri.symbol.SimpleMarkerSymbol().setSize(4);
var renderer = new esri.renderer.ClassBreaksRenderer( defaultSym,"clusterCount" );
console.log("hi");
console.log(photoInfo.data);
var one = new esri.symbol.PictureMarkerSymbol("http://geology.utah.gov/testing/fieldtrip/img/pic-stack-80px.png", 32, 32).setOffset(0, 15);
var two = new esri.symbol.PictureMarkerSymbol("http://geology.utah.gov/testing/fieldtrip/img/pic-stack2-80px.png", 44, 44).setOffset(0, 5);
var three = new esri.symbol.PictureMarkerSymbol("http://geology.utah.gov/testing/fieldtrip/img/pic-stack5-80px.png", 60, 60).setOffset(0, 5);
var four = new esri.symbol.PictureMarkerSymbol("http://geology.utah.gov/testing/fieldtrip/img/pic-stack6-80px.png", 72, 72).setOffset(0, 5);
renderer.addBreak(0, 2, one);
renderer.addBreak(2, 100, two);
renderer.addBreak(100, 200, three);
renderer.addBreak(200, 1001, four);
clusterLayer.setRenderer(renderer);
map.addLayer(clusterLayer);
map.infoWindow.resize(270, 316);
