Can anyone explain how to use the PopupExpressions of a PopupDefinition/Popup in relation to the PopupManager?
Let's say I have a simple PopupDefinition defined as below:
"allowDelete":false,
"allowEdit":false,
"allowEditGeometry":false,
"description":"",
"expressions":[{
"name":"expr1".
"title": "Expression Test",
"expression": "$feature.NAME",
"returnType":"string"
"fields":[{
"fieldName":"NAME",
"format":null,
"isEditable":false,
"isVisible":true,
"label":"Name Label",
"stringFieldOption":"singleLine",
"tooltip":""
"media":[],
"relatedFeaturesDefinition":null,
"showAttachments":true,
"showEditSummary":false,
"title":"{NAME}"
I can set this PopupDefinition to a FeatureLayer, query for Popups and get a result that shows both the Fields and Expressions are available. Passing the Popup to a PopupManager gives me access to the 'DisplayedFields' which I then use to bind to my view. Unfortunately, I don't understand how you access the expressions. I had thought that perhaps they could be referenced as PopupFields by adding additional Field values to the PopupDefinition such as the following:
"fieldName":"{expr1}",
"format":null,
"isEditable":false,
"isVisible":true,
"label":"Expression Label",
"tooltip":""
This however does not appear to work. How does one access PopupExpression results from a PopupManager?
