When I use the ESRI sample Print templates with esri.request (https://developers.arcgis.com/en/javascript/jssamples/widget_print_esri_request.html), I copy the code into a local html file, the "print" button doesn't display, however when I put an alert box in line 79, this somehow causes it to work in FireFox. To make debugging easier, I have replaced the original console.log() method to alert(). Any ideas?<!doctype html> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; } .shadow { -moz-box-shadow: 0 0 5px #888; -webkit-box-shadow: 0 0 5px #888; box-shadow: 0 0 5px #888; } #map{ margin: 0; padding: 0; } #feedback { background: #fff; color: #000; position: absolute; font-family: arial; height: auto; right: 20px; margin: 5px; padding: 10px; top: 20px; width: 300px; z-index: 40; } #feedback a { border-bottom: 1px solid #888; color: #444; text-decoration: none; } #feedback a:hover, #feedback a:active, #feedback a:visited { border: none; color: #444; text-decoration: none; } #note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; } #info { padding: 10px 0 0 0; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> var app = {}; require([ "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Print", "esri/tasks/PrintTemplate", "esri/request", "esri/config", "dojo/_base/array", "dojo/dom", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, FeatureLayer, Print, PrintTemplate, esriRequest, esriConfig, arrayUtils, dom, parser ) { parser.parse(); app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; esriConfig.defaults.io.proxyUrl = "/proxy"; app.map = new esri.Map("map", { basemap: "hybrid", center: [-117.447, 33.906], zoom: 17, slider: false }); // add graphics for pools with permits var permitUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/PoolPermits/MapServer/1"; var poolFeatureLayer = new FeatureLayer(permitUrl, { "mode": FeatureLayer.MODE_SNAPSHOT }); alert("Test"); // This is Line 79 ! This will work in FireFox, after commenting out, it will break app.map.addLayer(poolFeatureLayer); // get print templates from the export web map task var printInfo = esriRequest({ "url": app.printUrl, "content": { "f": "json" } }); printInfo.then(handlePrintInfo, handleError); function handlePrintInfo(resp) { var layoutTemplate, templateNames, mapOnlyIndex, templates; layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) { return param.name === "Layout_Template"; }); if ( layoutTemplate.length == 0 ) { alert("print service parameters name for templates must be \"Layout_Template\""); return; } templateNames = layoutTemplate[0].choiceList; // remove the MAP_ONLY template then add it to the end of the list of templates mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY"); if ( mapOnlyIndex > -1 ) { var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0]; templateNames.push(mapOnly); } // create a print template for each choice templates = arrayUtils.map(templateNames, function(ch) { var plate = new PrintTemplate(); plate.layout = plate.label = ch; plate.format = "PDF"; plate.layoutOptions = { "authorText": "Made by: Esri's JS API Team", "copyrightText": "<copyright info here>", "legendLayers": [], "titleText": "Pool Permits", "scalebarUnit": "Miles" }; return plate; }); // create the print dijit app.printer = new Print({ "map": app.map, "templates": templates, url: app.printUrl }, dom.byId("print_button")); app.printer.startup(); } function handleError(err) { alert("Something broke: ", err); } }); </script> </head> <body class="tundra"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="feedback" class="shadow"> <h3> Print Templates Created from Info Returned by the Print Service using <a href="https://developers.arcgis.com/en/javascript/jsapi/namespace_esri.html#request">esri.request</a> </h3> <div id="info"> <div id="note"> Note: This sample uses an ArcGIS Server version 10.1 export web map task. </div> <!-- that will be used for the print dijit --> <div id="print_button"></div> <div id="info"> <a href="https://developers.arcgis.com/en/javascript/jsapi/printtemplate.html">Print templates</a> are generated from the Export Web Map Task's <a href="http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task">Layout_Template parameter</a>. This info is retrieved from the service using <a href="https://developers.arcgis.com/en/javascript/jsapi/namespace_esri.html#request">esri.request</a>. </div> </div> </div> </div> </div> </body> </html>
