Has anyone else had issues trying to sort fields on related tables? All of my other layers can be sorted. I thought it might be an issue that was brought up earlier with pagination with our Oracle db so I moved it to a current version of Postgresql and had no luck there either. I've also tried multiple themes to eliminate that possibility. This is Web AppBuilder 1.3 Developer with 10.3.1 Server.
Shawn,
I can confirm that sorting related tables by column does not work in the Attribute Table widget. You need to contact esri tech support and report this bug.
Will do, thanks for verifying it for me Robert!
