I have around 40000 borehole data with soil classification in certain depths. My scope of the project is to create soil map by interpolate all the borehole data's and create the soil map and publish the same in the web (3D) . My idea is to create TIN and publish the TIN in ArcGIS server is it correct technique? and how to publish the TIN in ArcGIS server?. Kindly let me know how to proceed?
What is the version of ArcGIS Desktop/Server you are working on? Do you also have ArcGIS Pro/ Portal for ArcGIS?
ArcGIS server version 10.4. I understand that ArcGIS Pro/ Portal is needed to publish . My primary doubt is that whether I can publish TIN format in ArcGIS server straight away?.
Yes. TIN layers are supported.
Thanks for the reply. I need to create .sxd file (ArcScene document) to publish in ArcGIS server am I right?. Because TIN layer is not supported in MXD.
