Could not create network dataset. Table not registered [CARTO.N_2_TurnWeight] Table attachments not supported in this release of the Geodatabase. Table not registered [CARTO.N_2_EdgeWeight] Table attachments not supported in this release of the Geodatabase. Table not registered [CARTO.N_2_JunctionWeight] Table attachments not supported in this release of the Geodatabase. Table not registered [CARTO.N_2_Topology] Table attachments not supported in this release of the Geodatabase. Table not registered [CARTO.N_2_Desc] Table attachments not supported in this release of the Geodatabase. Table not registered [CARTO.N_2_Props] Table attachments not supported in this release of the Geodatabase. Underlying DBMS error [Error executing stored procedure <schema>.spref_util.insert_spatial_ref::ORA-01653: impossible d'étendre la table SDE.ST_SPATIAL_REFERENCES de 8 dans le tablespace SDE] System junction source does not exist. ---------------------------
We experienced this same problem also with oracle 11g/SDE 10.2 and Desktop 10.1. The solution that seemed work was to shorten the name of the network dataset we were trying to create...
