Hi brains trust. I have heard that it is possible to edit a Feature Service hosted in ArcOnline using ArcPro? Can someone point me in the right direction of how to do this? Currently we edit FS layers in ArcMap (Make a Local Copy for Editing/Synchronise...) but are trying to migrate ourselves to ArcPro gradually. I can't for the life of me figure out how to do it or find any clearly written material explaining the process.
Figured out the next bit too. After selecting the desired areas, right clicking and going "Copy", the "Paste" button in the "Edit" ribbon > "Clipboard" pane lights up. Clicking the little drop-down arrow gives you the option to "Paste Special".
Click this and set the Target Layer and check the "Keep source attribute values" option
NOTE: Because there is no Undo option, you also don't have to Save!
I have progressed! Once I had set the Feature Service to Editable in ArcOnline, it didn't refresh in ArcPro straight away. Closed down the project and started again. Now I can select features and delete them.
NOTE: There is no UNDO option!
Now, I'm trying to copy in new features from a local layer. I select the shapes, right click and select "Copy", but can't seem to Paste them into the AGOL layer - only back into the local layer.
