I searched through the forums and significant online searches to find an answer to this with no success.
I am running ArcPro version 2.4.0
What I want to do is simple. I want to display only items under a certain heading of a layer, that is symbolized using unique values, within the legend.
Example: In ArcMap 10.7 I can go into the Layer Properties, "Symbology", right click the value i want and select "Move to Heading" and assign it to a new heading. I then go into the "Legend Item Properties" dialog box and there is an option to "Only show classes from this heading".
For this example, I want to take a series of right of way lines and display them in the legend in two categories "New" and "Existing". There are more than one value that represents these categories and i just want the legend to display two of the categories that i have assigned to new headings ("groups" in ArcPro).
I could do this easily in ArcMap by using the above method and adding one representative value for each category to a new heading and only showing that heading in the legend.
I cannot seem to find this option in ArcPro. I am able to assign the values to a "New Group" but have not been able to find a way to display only that group in the legend.
I know there are other, more tedious, methods to get this result (e.g. dissolve the values, turn the legend into a graphic and remove the unwanted layer references, etc.) but i am hoping this feature is still available in Pro and i just cant find it.
Thanks for any help!
