I am trying to create a model where I add multiple new fields to a feature class and to do some other geoprocessing tasks. Is there a way to choose what the field names will be based on user input? I have one field that I add to the feature class which depends on what the data represents and I was wondering if there is a way where I can when running the model select one of two options to what the field should be called. I also wanted to do it so that I could select whether it will add the WAperiod field. I am pretty new to this so I can imagine its something very simple
Brilliant! thanks for the help guys
It's pretty easy to create a string parameter value filter to set the choices to a limited list of strings. When the model tool is run, it will present a picklist of keywords (which can be the same as the list of field names you want).
Value list filter—Help | ArcGIS Desktop
Model parameters—ArcGIS Pro | ArcGIS Desktop
If you want the model to figure out the name without the user having to know, branching your model (as Dan suggests) is an option, but I think it's easier to use Calculate Value to calculate your field name. Either approach will require some scripting.
<SPAN class="comment token"># Calculate Value Expression</SPAN> GetFieldName<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"%table%"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Code Block</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">GetFieldName</SPAN><SPAN class="punctuation token">(</SPAN>tbl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># use field name to figure out what sort of table, </SPAN> <SPAN class="comment token"># if KEYFIELD is not there, returns empty (false)</SPAN> <SPAN class="comment token"># and field name is assigned "FIELDNAME2"</SPAN> <SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"KEYFIELD"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> fname <SPAN class="operator token">=</SPAN> <SPAN class="string token">"FIELDNAME1"</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> fname <SPAN class="operator token">=</SPAN> <SPAN class="string token">"FIELDNAME2"</SPAN> <SPAN class="keyword token">return</SPAN> fname <SPAN class="comment token"># Data Type</SPAN> String<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
As for providing options as to which field name to choose, you can check the 'branching' section of modelbuilder to see how 'if-else' conditions are implemented.
