I have inherited a VBA application that we use to notify land owners of changes in zoning near their properties. I did not write the original application and I have not done much programming in VBA. I am currently working on replacing this application with a python add-in, but a change in state law is forcing me to update the VBA application because of time constraints. The new state law requires that with any zoning cases municipalities must notify school districts of any changes in zoning that occur within the district boundaries. I have create a polygon feature class of the school districts with the mailing addresses for each district. Users can choose to select one or more parcels or zoning case polygons or choose to select a polygon shapefile to designate the area being rezoned. The application then converts these polygons to a graphic element and then creates a graphical buffer around first graphic. These graphics are then use select the parcels that intersect the combined graphics, select the corresponding records in a related tax roll table and export the results into a dbf file. I want to use a spatial filter to select any school district polygons that intersect the shapefile polygons or the original selection before the graphics are created. Then store the selected records in a global selectionset and insert the records into the final dbf. I have tried to create a procedure to do this, but it keeps crashing on me. Here is what I have so far: Public Sub SelectSchoolDistrict() Dim pMxApp As IMxApplication Dim pMap As IMap Dim pMxDoc As IMxDocument Dim pActiveView As IActiveView Dim pEnumFeature As IEnumFeature Dim pFeature As IFeature Set pMxApp = Application Set pMxDoc = Application.Document Set pActiveView = pMxDoc.FocusMap Set pMap = pMxDoc.FocusMap Dim pFeatureCursor As IFeatureCursor Dim pFeatureSelection As IFeatureSelection Dim pSelectionSet As ISelectionSet Set pFeatureSelection = pMxDoc.FocusMap.Layer(1) 'FeatureSelection Set pSelectionSet = pFeatureSelection.SelectionSet m_SetSelectableLayer ("School District") If ThisDocument.g_Model = 2 Then Dim pISDLayer As IFeatureLayer Dim pSearchLayer As ILayer Dim ISDcount As Integer For ISDcount = 0 To pMxDoc.FocusMap.LayerCount - 1 Set pSearchLayer = pMxDoc.FocusMap.Layer(ISDcount) If pSearchLayer.Name = "School Districts" Then Set pISDLayer = pSearchLayer Exit For End If Next Dim pISDfSel As IFeatureSelection Set pISDfSel = pISDLayer Dim pEnumParcelIDs As IEnumIDs Set pEnumParcelIDs = pSelectionSet.IDs Dim pGeoCollParcel As IGeometryCollection Set pGeoCollParcel = New GeometryBag Dim count As Long For count = 1 To pSelectionSet.count pGeoCollParcel.AddGeometry pISDLayer.FeatureClass.GetFeature(pEnumParcelIDs.Next).Shape Next count Dim pISDSpatialFilter As ISpatialFilter Set pISDSpatialFilter = New SpatialFilter With pISDSpatialFilter Set .Geometry = pGeoCollParcel .GeometryField = "Shape" .SpatialRel = esriSpatialRelContains End With pISDfSel.SelectFeatures pISDSpatialFilter, esriSelectionResultNew, False Set gISDSelectionSet = pISDfSel.SelectionSet End If 'End Section to add ISD addresses End Sub I would appreciate any help or advise that anyone can offer.
