Hello. I hope all is well to whomever is reveiwing this post. First off, I realize that the following question may very well be one of those face palm moments for me. I tend to have them more often than not, so I'm ready. I work with a few clients and now a couple have AGO instead of Portal
The issue is custom widget deployment. I have been working with WAB (embedded) with a Portal Setup. No worries here as the custom widget shows up in the WAB interface. Easy Peezy! Using custom widgets for an ArcGIS online setup for me at the moment is like hitting a major league curve. I have downloaded the WAB-DEV edition and successfully installed it, At least according to the documentation and videos I have watched. I understand how to pull in a custom code (not yet ready to write my own).
Ok, I get that as part of the setup, there is a requirement of registering the instance with the client with whom I am working. (BTW, can there be multiple instance of WAB-DEV on my laptop- one for each client?). The main question I have is when ready to Deploy, am I correct in thinking that the application (with the custom widget) can be on any web facing server?, perferably the client's own webserver. This way the web app is on a local webserver but it is still access the arcgis online organizational account for data.
Sorry if the above sounds confusing. If any one can confirm I am on the right side of the road, or if not, maybe help me get on track.
thanks, Stay well and Healthy.
