Hello
I am wanting to use the screening widget to supply address lists in csv when users either draw a boundary or use the buffer. This works really well except that the exported csv uses the word "no data" when there is a blank field this renders the file useless when used in a mail merge. I have used fme to remove the null values and replace with a space but this has not helped. Is there any way either in the widget or the map used in the app to get rid of the "no data" wording? Using Portal 10.6.1.
Thank you in advance
