I was wondering how the XY tolerance / resolution is used in the Utility Network. To test this, I first loaded the feature classes from an asset package as simple feature classes into an enterprise geodatabase. Here, I didn't got any load errors like self-intersecting points nor duplicated vertices.
In my second test, I deployed the asset package. The Territory feature class has a resolution of 0,0001meter & tolerance of 0,001meter (like my initial feature classes). After enabling network topology, I see a lot of self-intersecting & duplicated vertices errors.
If I zoom into the errors, I see the distance between 2 vertices for error line is >2mm, which I believe is not withing the XY tolerance. So, why do I get all these errors?
is there another way to define the XY tolerance / resolution in the utility network?
thanks,
Jan
