I have created an intervention management application on a sanitation network with the webappbuilder. I would like to generate alerts regarding the dates of completion of the work with Arcade for ArcGIS. Someone knows how to create an Arcade script to generate alerts with different colors from the start date of the work and the maximum completion date.
Thanking you in advance!
Thank you
Hi Bazile Gagre ,
If your due date is an attribute of your features, you can base your symbology on the difference between the due date and the current date. You should probably include the completion date or status too in order to handle those assignments that have been completed.
Your expression could look something like this:
<SPAN class="comment token">// make sure you point to the correct fields</SPAN> <SPAN class="keyword token">var</SPAN> dueDate <SPAN class="operator token">=</SPAN> $feature<SPAN class="punctuation token">.</SPAN>dueDate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> completedDate <SPAN class="operator token">=</SPAN> $feature<SPAN class="punctuation token">.</SPAN>completedDate<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="token function">IsEmpty</SPAN><SPAN class="punctuation token">(</SPAN>completedDate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// task is not completed yet</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"completed"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// task is not completed yet, determine days to due date</SPAN> <SPAN class="keyword token">var</SPAN> daysDif <SPAN class="operator token">=</SPAN> <SPAN class="token function">DateDiff</SPAN><SPAN class="punctuation token">(</SPAN>dueDate<SPAN class="punctuation token">,</SPAN> <SPAN class="token function">Today</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"days"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">Console</SPAN><SPAN class="punctuation token">(</SPAN>daysDif<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// classify time to due date</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>daysDif <SPAN class="operator token">>=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"more than 3 days to due date"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>daysDif <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"only "</SPAN> <SPAN class="operator token">+</SPAN> daysDif <SPAN class="operator token">+</SPAN> <SPAN class="string token">" day(s) to due date"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>daysDif <SPAN class="operator token">==</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"only 1 day to due date"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>daysDif <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"due date is today!"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Due date has passed!"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> result<SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You're welcome gagbaz . However, you marked you own answer with "Thank you" as the correct answer. The idea is that other users can find the correct answer easier, so maybe you can correct that?
