I have some layers that i need to change the data source for.The current script i have gives me the following error. I don't know why.if anyone would be kind to help me out please?thanks.
import arcpy
from arcpy import env
from arcpy import mapping
workspace = arcpy.env.workspace = "C:/GIS/MAPBOOK/Proposed Zoning Book"
mxdList = arcpy.ListFiles("*.mxd")
for mxd in mxdList:
mxd = workspace + "//" + mxd
for lyr in arcpy.mapping.ListLayers(mxd):
if lyr.name == "PROPOSED ZONING":
lyr.replaceDataSource("C:/Users/t***a/AppData/Roaming/ESRI/Desktop10.1/ArcCatalog/DSD15_SQLEXPRESS.gds/DSD/DSD.DBO.MUNICIPALITY", "SHAPEFILE_WORKSPACE", "DSD.DBO.FUTURE_LAND_USE_ZONING")
if lyr.name == "CITY LIMITS":
lyr.replaceDataSource("C:/Users/t***a/AppData/Roaming/ESRI/Desktop10.1/ArcCatalog/DSD15_SQLEXPRESS.gds/TonyOneWay/TonyOneWay.DBO.Canyon_Features", "SHAPEFILE_WORKSPACE", "TonyOneWay.DBO.City_Limits")
print "Successfully updated data sources"
mxd.save()
Error
File "C:\GIS\Python Scripts\Change Data Source MXD 2.py", line 13, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_
return fn(*args, **kw)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\mapping.py", line 1500, in ListLayers
result = mixins.MapDocumentMixin(map_document_or_layer).listLayers(wildcard, data_frame)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 823, in listLayers
layers = self.layers
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 683, in layers
for frame in reversed(self.dataFrames):
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 695, in dataFrames
return map(convertArcObjectToPythonObject, self.pageLayout.dataFrames)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 679, in pageLayout
return convertArcObjectToPythonObject(self._mxd._arc_object.pageLayout)
AttributeError: 'unicode' object has no attribute '_arc_object'
