I have configured an ArcGIS WebApplicationBuilder Map as an application in ArcGIS Online. It is consumed by IIS6 on a Windows 2003 Server Machine. When I hit the URL; I receive ERROR 400 Invalid URI_indirect. My application was copied to my server from AGOL. What is the solution for this if I am not using WebAppBuilder in Development mode? What should my URI be when I register the app in AGOL?
Geoffrey,
The url you should use to register the app is the url that you use to see the app (i.e. http://gisdev01/LifeSupportApplication/).
Thanks Robert,
What about the URI error?
On Fri, Jul 15, 2016 at 3:50 PM, Robert Scheitlin, GISP <geonet@esri.com>
You have me confused again. I thought we were talking about properly registering the app so that you would not get a URI error.
Geoffrey ,
Did you add the downloaded files from AGOL as an application in your IIS or your site root folder (wwwroot)?, if you did that of IIS then make sure you do this set up as illustrated below, however if otherwise then it should just work@@:
1. Click on the basic settings as in figure below on the right side of your IIS Manager:
2. Connect As: using the "Specific User" (Preferably an admin account that never changes)
3. Test setting: Make sure the result are ticked green
Now you can test your site......Hope this is useful
Babatope,
I am using IIS6, is the Directory security tab for each virtual directory similar to the example that you have provided?
I am receiving an invalid URI error, but I have the correct correct URL configured in the app settings in AGOL.
