I have a customer request to modify the panning mouse click functionality in a web app to mimic another application they use. They want to make it so that clicking down on the center scroll wheel of the mouse and holding down allows for the panning in the map. Any distant chance anyone as done this or knows what to modify in the application code to do this?
Thanks Robert
George,
WABs jimu/main.js specifically disables the wheel button (normally when you see a programmer do something like this there is a good reason).
<SPAN class="comment token">// disable middle mouse button scroll</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>window<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'mousedown'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>mouse<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isMiddle</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">preventDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>returnValue <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
