So I'm working with an AGOL and WAB and building out application. I want the filter widget to be present in my mobile web app. Can someone point me in right direction in regards to having the filter widget accessible in the web map via mobile devices. Documentation links or insights.
Ever find a solution for this, Jeff? I need similar functionality in a workflow of ours; different teams using Explorer/Collector who want to filter down their points for their assigned areas.
-Aaron
Just download it and clicking through it seems to be a fit to view all the WAB's we've built. Although another app to use and just got field guys comfortable using explorer app. Is there a way to get the filter button applied on the web map itself by modifying it somehow. I was wanting to add the functionality to an existing web map
Yeah that works and i can get to it fairly easily but i have my field guys all using the explorer app so trying to get them to do something different...well whole another task
Jeff,
In your orgs content you will see your WAB apps listed and there is a button on the right hand side that says "View Application" that button will take you to the url that you need to use on your devices (desktop or mobile). I am not familiar with the explorer app so I can't say much about that.
I believe Explorer only shows the maps. If you need to look at the apps and can't do so in a web browser, have you tried ArcGIS Companion? It's another mobile app that allows you to easily view the configured web apps on your device.
Understood, but on my mobile device I don't see the WAB app that is reading off of the original web map created. On the Explorer app all i see is all the web map's created and not the ones created using WAB. So that's were I'm stumped. I got the filter to work in WAB app. So a couple of questions, Is that expected or should i see the WAB apps in explorer app. How do a get that WAB app accessible. I know I'm probably missing steps here.
AGOL WAB apps are responsive apps that will work on desktop or mobile. So if you add the filter widget to your WAB app it will also be available in your WAB app when viewed on a mobile device.
