I'm having troubles adding features to a Local GDB in Qt. Following this code:
Geodatabase {
path: "Test/FS_SNM_ALS_LimpiezaSumideros.geodatabase" onValidChanged: {
if (valid) {
var gdbtables = gdb.geodatabaseFeatureTables;
for(var i in gdbtables) {
console.log (gdbtables.featureServiceLayerName);
FeatureLayer {
featureTable: gdb.geodatabaseFeatureTableByLayerId(0)
function addFeature(mapPoint) {
console.log("x", mapPoint.x);
var featureJson = {
geometry: {
x: mapPoint.x,
y: mapPoint.y,
spatialReference: mapPoint.spatialReference
attributes: {
<attributes>
if (featureLayer.featureTable.featureTableStatus === Enums.FeatureTableStatusInitialized) {
featureLayer.featureTable.addFeature(featureJson);
When running the code, it seems like the feature was added, but it can't be queried or be seen on the map
Any comment is helpful! Thank you!
cc: jumypansas
