search widget will not displace the parcel parameters of the related tables data when a search is performed. The parcel feature class has a relationship in the SDE with a table and only table information is displayed but when you click on the record it will not zoom to it. please help on xml code.
Raul,
In version 3.4 of the widget there was not a full GUI for configuring the eSearch Widget in app builder. In 3.7 of ArcGIS Viewer for flex there is a FULL GUI for configuring the widget that takes all the need to know XML out of the equation.
You have done well configuring the other layers, all you need to do is move the "County Parcels" from the tables to a layer and then add some fields besides the GIS_Data_file_as_name (just like you have for your other layers), and like I said earlier use:
<relates> <relate id="0" label="County Parcels" enableexport="true" icon="widgets/eSearch/assets/images/i_relate.png" enableprintgrid="true" printitle="County Tax Roll"> <fields all="true"/> <zoomscale usegeometry="true" zoompercent="1.6"/> </relate> </relates>
Please attach what you have in your eSearchWidget.xml currently.
<?xml version="1.0" ?>
<configuration>
<layers>
<layer>
<definitionexpression/>
<enableexport>true</enableexport>
<name>McAllen Parcels</name>
<url>http://gismap.mcallen.net/mcgis/rest/services/ParcelEditing/MapServer/10</url>
<expressions>
<expression alias="Owners Name" textsearchlabel="Property Owner's Information">
<values>
<value prompt="Owner's Name Ex: Doe John">upper(LAST_FIRST) LIKE upper('%[value]%')</value>
</values>
<value prompt="Owner's City Ex: McAllen" isvaluerequired="false">upper(OWNERCITY) LIKE upper('%[value]%')</value>
</expression>
<expression alias="GEO ID" textsearchlabel="Property Tax Information">
<value prompt="Geographic ID Ex: M1950-00-061-0000-00">GEO_ID = '[value]'</value>
<value prompt="Property ID Ex: 229138" isvaluerequired="false">PROP_ID = '[value]'</value>
<expression alias="Zip Code" textsearchlabel="Search By Zip Code:">
<value prompt="Example: 78501">upper(OWNERZIP) LIKE upper('%[value]%')</value>
</expressions>
<graphicalsearchlabel>Use one of the graphical search tools to select McAllen Parcels</graphicalsearchlabel>
<spatialsearchlayer>true</spatialsearchlayer>
<titlefield>GEO_ID</titlefield>
<fields all="false">
<field name="GEO_ID" alias="GEO ID" hyperlinkgridfield="false" gridfield="true"/>
<field name="PROP_ID" alias="Prop ID" hyperlinkgridfield="false" gridfield="true"/>
<field name="PIDN" alias="PIDN" hyperlinkgridfield="false" gridfield="true"/>
<field name="LAST_FIRST" alias="Last, First" gridfield="true" gridfieldonly="true"/>
<field name="LAST_NAME" alias="Owner's Last Name" gridfield="true" gridfieldonly="true"/>
<field name="FIRST_NAME" alias="Owner's First Name" gridfield="true" gridfieldonly="true"/>
<field name="ADRS_1" alias="Owner's Addr1" gridfield="true" gridfieldonly="true"/>
<field name="ADRS_2" alias="Owner's Addr2" gridfield="true" gridfieldonly="true"/>
<field name="OWNERADD_2" alias="Owner's Addr3" gridfield="true" gridfieldonly="true"/>
<field name="OWNERCITY" alias="Owner's City" gridfield="true" gridfieldonly="true"/>
<field name="OWNERSTATE" alias="Owner's State" gridfield="true" gridfieldonly="true"/>
<field name="OWNERZIP" alias="Owner's Zip Code" gridfield="true" gridfieldonly="true"/>
<field name="LEGALDESCR" alias="Legal Decription" gridfield="true" gridfieldonly="true"/>
<field name="LEGAL_2" alias="Legal 2" gridfield="true" gridfieldonly="true"/>
<field name="PROPERTYUS" alias="Property Use" gridfield="true" gridfieldonly="true"/>
<field name="LANDVALUE" alias="Land Value" gridfield="true" gridfieldonly="true"/>
<field name="IMPROVALUE" alias="Improvement Value" gridfield="true" gridfieldonly="true"/>
<field name="STREET" alias="Street" gridfield="true" gridfieldonly="true"/>
<field name="STREETNUMB" alias="Street Number" gridfield="true" gridfieldonly="true"/>
<field name="BLOCKNUMBE" alias="Block Number" gridfield="true" gridfieldonly="true"/>
<field name="STREETDIRE" alias="Sreet Direction" gridfield="true" gridfieldonly="true"/>
<field name="STREETNAME" alias="Sreet Name" gridfield="true" gridfieldonly="true"/>
<field name="STREETSUFF" alias="Street Suffix" gridfield="true" gridfieldonly="true"/>
<field name="UNITNUMBER" alias="Unit Number" gridfield="true" gridfieldonly="true"/>
<field name="SITUSADDRE" alias="Situs Address" gridfield="true" gridfieldonly="true"/>
<field name="YEAR" alias="Year" gridfield="true" gridfieldonly="true"/>
<field name="SUBDIVISIO" alias="Subdivision" gridfield="true" gridfieldonly="true"/>
<field name="BLOCK" alias="Block" gridfield="true" gridfieldonly="true"/>
<field name="LOT" alias="Lot" gridfield="true" gridfieldonly="true"/>
<field name="SPLITS" alias="Splits" gridfield="true" gridfieldonly="true"/>
<field name="Entities" alias="Entities" gridfield="true" gridfieldonly="true"/>
<field name="HCAD" alias="HCAD" gridfieldonly="true" hyperlinkgridfield="true" hyperlinkaliastext="Hidalgo County Appraisal" visible="false" hyperlinkgridicon="assets/images/TaxDoc.png"/>
</fields>
<links>
<link alias="View Link" disablelinksifnull="true">
<![CDATA[{URL}]]>
<icon><![CDATA[assets/images/TaxDoc.png]]></icon>
</link>
</links>
<zoomscale>102100</zoomscale>
<zoomscale usegeometry="true" zoompercent="2"/>
<autoopendatagrid>true</autoopendatagrid>
<queryattachments>false</queryattachments>
<relates/>
<symbology>
<simplefillsymbol color="0xffcc99" alpha="0.3">
<outline color="0xff0000" alpha="0.8" width="2"/>
</simplefillsymbol>
</symbology>
</layer>
<name>Subdivision</name>
<url>http://gismap.mcallen.net/mcgis/rest/services/ParcelEditing/MapServer/14</url>
<expression alias="Subdivision" textsearchlabel="Search Only McAllen Subdivisions">
<value prompt="Example: Shadow Brook">upper(SUBD) LIKE upper('%[value]%')</value>
<graphicalsearchlabel>Use one of the graphical search tools to select Parcels</graphicalsearchlabel>
<titlefield>Subdivision</titlefield>
<field name="SUBD" alias="Subdivision" gridfield="true"/>
<links/>
<zoomscale>200000</zoomscale>
<forcescale>true</forcescale>
</layers>
<tables>
<table>
<name>County Parcels</name>
<url>http://gismap.mcallen.net/mcgis/rest/services/ParcelEditing/MapServer/13</url>
<expression alias="Owner's Name" textsearchlabel="Property Owner's Information">
<value prompt="Owner's Name Ex: Doe John">upper(GIS_Data_file_as_name) LIKE upper('%[value]%')</value>
<value prompt="Owner's City Ex: McAllen" isvaluerequired="false">upper(addr_city) LIKE upper('%[value]%')</value>
<value prompt="Geographic ID Ex: M1950-00-061-0000-00">GIS_Data_geo_id = '[value]'</value>
<value prompt="Property ID Ex: 229138" isvaluerequired="false">GIS_Data_prop_id = '[value]'</value>
<expression alias="ZIp Code" textsearchlabel="Search By Zip Code:">
<value prompt="Example: 78501">upper(zip) LIKE upper('%[value]%')</value>
<graphicalsearchlabel>Use one of the graphical search tools to select County Parcels</graphicalsearchlabel>
<titlefield>GIS_Data_prop_id</titlefield>
<field name="GIS_Data_file_as_name" alias="HFile As Name" gridfield="true" gridfieldonly="true"/>
<relates>
<relate id="prop_id" label="County Parcels" enableexport="true" icon="widgets/eSearch/assets/images/i_relate.png" enableprintgrid="true" printitle="County Tax Roll">
</relate>
</relates>
</table>
</tables>
<spatialrelationships>
<spatialrelationship>
<name>esriSpatialRelContains</name>
<label>entirely contained in</label>
</spatialrelationship>
<name>esriSpatialRelIntersects</name>
<label>intersected by</label>
<name>esriSpatialRelEnvelopeIntersects</name>
<label>intersected by envelope of</label>
</spatialrelationships>
<bufferunits>
<bufferunit>
<name>UNIT_FOOT</name>
<label>Feet</label>
</bufferunit>
<bufferunit selected="true">
<name>UNIT_STATUTE_MILE</name>
<label>Miles</label>
<name>UNIT_METER</name>
<label>Meters</label>
<name>UNIT_KILOMETER</name>
<label>Kilometers</label>
</bufferunits>
<buffervalue>2</buffervalue>
<printdatagrid>
<addheadertoeachpage>true</addheadertoeachpage>
<columnheaderbgcolor>0xa7a7a7</columnheaderbgcolor>
<columnheaderfontcolor>0x000000</columnheaderfontcolor>
<footer>
<pageoftext>Page ## of ##</pageoftext>
<includeprintdate format="MM-DD-YYYY L:NN A">true</includeprintdate>
<disclaimer/>
</footer>
</printdatagrid>
<removeserchlayersminmaxscale>false</removeserchlayersminmaxscale>
<keepgraphicalsearchenabled>true</keepgraphicalsearchenabled>
<autozoomtoresults>200000</autozoomtoresults>
<popupsdisabled>false</popupsdisabled>
<enabledatagridinteractionwithwidget>true</enabledatagridinteractionwithwidget>
<toleranceforpointgraphicalselection>6</toleranceforpointgraphicalselection>
<tolerancebydefault>false</tolerancebydefault>
<spatialreference>200000</spatialreference>
<zoomscale>2400</zoomscale>
<csvseparator>,</csvseparator>
<textqualifier>"</textqualifier>
<disablebuttons/>
<defaultselectionoption>textInput</defaultselectionoption>
<enabledrawgraphicbutton>true</enabledrawgraphicbutton>
<enablebuffergraphicbutton>true</enablebuffergraphicbutton>
<enablelocategraphicbutton>true</enablelocategraphicbutton>
<enablemultigraphicssearch>false</enablemultigraphicssearch>
<enableincludetextsearch>true</enableincludetextsearch>
<enableaddtollerance>true</enableaddtollerance>
<enablegraphicsbuffering>true</enablegraphicsbuffering>
<enableprintgrid>true</enableprintgrid>
<selectedgraphicaltool/>
<multipartgraphicsearch>false</multipartgraphicsearch>
<floatorfixed>float</floatorfixed>
<relatetooltip>Show Relates</relatetooltip>
<relateicon>widgets/eSearch/assets/images/i_relate.png</relateicon>
<labels>
<urlsearcherrormessage>URL search parameters are incorrect</urlsearcherrormessage>
<includetextquery>include text query in selection criteria</includetextquery>
<includetextquerywarn>Must be the same search layer in both
graphical and text search pages.</includetextquerywarn>
<buffergrapicprops>Buffer graphic properties</buffergrapicprops>
<bufferusergraphics>Buffer Graphic</bufferusergraphics>
<norelatesfound>No related features found for:</norelatesfound>
<norelatesfoundalerttitle>No Results</norelatesfoundalerttitle>
<addtolerance>Add search tolerance to point selection</addtolerance>
<existingdrawgraphicslabel>Use Existing Enhanced Draw Widget Graphics</existingdrawgraphicslabel>
<existinglocategraphicslabel>Use Existing Enhanced Locate Widget Graphics</existinglocategraphicslabel>
<existingbuffergraphicslabel>Use Existing Point Buffer Widget Graphics</existingbuffergraphicslabel>
<graphicalsearchlabel>Graphical Search</graphicalsearchlabel>
<textsearchlabel>Text Search</textsearchlabel>
<resultslabel>Results</resultslabel>
<layerlabel>Search Layer:</layerlabel>
<layerfieldlabel>Search Layer Field:</layerfieldlabel>
<nolayerlabel>No search layer defined.</nolayerlabel>
<submitlabel>Search</submitlabel>
<pointlabel>Select by Point</pointlabel>
<linelabel>Select by Line</linelabel>
<rectanglelabel>Select by Rectangle</rectanglelabel>
<polygonlabel>Select by Polygon</polygonlabel>
<clearlabel>Clear</clearlabel>
<loadinglabel>Loading...</loadinglabel>
<selectionlabel>Features Selected:</selectionlabel>
<gridresultslabel>Show Results in Grid</gridresultslabel>
<csvdefaultname>Selected Records</csvdefaultname>
<relatescsvdefaultname>Related Records</relatescsvdefaultname>
<exportbtnlabel>Export...</exportbtnlabel>
<export2csvoptionlabel>Export to CSV...</export2csvoptionlabel>
<export2txtoptionlabel>Export to Txt...</export2txtoptionlabel>
<bufferlabel>apply a search distance:</bufferlabel>
<spatialsearchlabel>Spatial search</spatialsearchlabel>
<applybufferlabel>Apply buffer</applybufferlabel>
<searchlayerlabel>Search entities of:</searchlayerlabel>
<enablemultipartsearch>enable multi-part graphics</enablemultipartsearch>
<zoomalllabel>Zoom</zoomalllabel>
<zoomalltip>Zoom to all results</zoomalltip>
<bufferalpha>Fill opacity</bufferalpha>
<buffercolor>Fill color</buffercolor>
<nobuffercolor>No fill color</nobuffercolor>
<bufferoutlinecolor>Outline color</bufferoutlinecolor>
<nobufferoutlinecolor>No outline color</nobufferoutlinecolor>
<bufferoutlinewidth>Outline Width</bufferoutlinewidth>
<configbuffergra>Configure buffer graphic properties...</configbuffergra>
<required>*</required>
<requiredtooltip>This field is required.
Enter a value to enable search button</requiredtooltip>
<selectmethodtip>Click to change the selection method</selectmethodtip>
<newselectionmethodtip>Create new selection</newselectionmethodtip>
<addselectionmethodtip>Add to current selection</addselectionmethodtip>
<removeselectionmethodtip>Remove from current selection</removeselectionmethodtip>
<pagingqueryerrormsg>Four unsucessfull attempts was made to get unique values for</pagingqueryerrormsg>
</labels>
<symbols>
<simplefillsymbol color="0x00ffff" alpha="0.5">
<picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0"/>
<simplelinesymbol color="0xff0000" alpha="0.8" width="2"/>
</symbols>
</configuration>
Your relate id should be a number.
Thanks Robert for your quick response, I have assigned the relate number as you indicated and now i get an error #1009
Robert,
thanks for all your help! i just added the County Parcels as a layer and works!!
thank you so much you don't know how much i have been working on this change on my parcels gis map.
thanks again!
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
Thanks for marking one of my replies as helpful. Can you also mark it as answered (this is more important for people finding the correct answer).
All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you (you will have to do this from the actual thread as this is not visible in your inbox or activity stream).
Robert, if i want to upgrade to latest version of viewer for flex 3.7, what are the items to get affected.
Download the App Builder for 3.7 and see if it will upgrade your existing App Builder apps. There has been some changes between 3.4 and 3.7 but it should not be hard to update.
Robert, the upgrade changes what and also did the enhanced widget changed alot and what did from version 3.4 to 3.7
