I've got a CGA rule that creates a building that has a pedestal and 2 towers on top of the pedestal. The towers are set back from the edge of the pedestal and then extruded, they look okay as well except that duplicate walls are created that extend from the edge of the pedestal, as in the image below:[ATTACH=CONFIG]30640[/ATTACH]the code I used is below, can anyone tell me what I did to cause this phenomenon?Pedestal --> extrude(world.y, ((Num_Pedestal_Floors * Upperfloor_Height) + (Groundfloor_Height - Upperfloor_Height))) PedBuildingVolume3D PedBuildingVolume3D --> case (Groundfloor_Height != (Num_Pedestal_Floors * Upperfloor_Height) + (Groundfloor_Height - Upperfloor_Height)) : #pedestal height is NOT equal to height of just the ground floor # the 3d volume will be split into smaller 3d volumes ! 1 ground floor volume will be created. split(y) {Groundfloor_Height : Volume("GF") | ~1 : PedAllUpperFloors} else: Volume("GF1") Towers PedAllUpperFloors --> # the rest of the volume is not split into upper floor volumes, as many times as possible ('*' sign) split(y) {~Upperfloor_Height : Volume("UF")}* Towers Volume(volumeType) --> case volumeType == "GF1" : case ((split.index == 0) && (NumFlrsComm >= 1)): comp(f){side: Simple_Com | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) CommReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix >= 1)): comp(f){side: Simple_Mix | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) MixReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix == 0) && (NumFlrOff >= 1)): comp(f){side: Simple_Off | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) OffReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix == 0) && (NumFlrOff == 0)): comp(f){side: Simple_Res | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) ResReporting MassReporting else: NIL case volumeType == "GF" : case ((split.index == 0) && (NumFlrsComm >= 1)): comp(f){side: Simple_Com | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) CommReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix >= 1)): comp(f){side: Simple_Mix | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) MixReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix == 0) && (NumFlrOff >= 1)): comp(f){side: Simple_Off | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) OffReporting MassReporting case ((split.index == 0) && (NumFlrsComm == 0) && (NumFlrMix == 0) && (NumFlrOff == 0)): comp(f){side: Simple_Res | bottom: FloorBottom | top : Top | all: NIL } set(material.opacity,OpacityVal) ResReporting MassReporting else: NIL case volumeType == "UF" : case (((split.index + 1) <= (NumFlrsComm - 1)) && (NumFlrsComm > 1)): comp(f){side: Simple_Com | bottom: FloorBottom | top : Top } CommReporting MassReporting case (((split.index + 1) > (NumFlrsComm - 1)) && (NumFlrMix > 0) && ((split.index + 1) <= ((NumFlrsComm + NumFlrMix) - 1))): comp(f){side: Simple_Mix | bottom: FloorBottom | top : Top } MixReporting MassReporting case (((split.index + 1) > ((NumFlrsComm - 1) + (NumFlrMix - 1))) && (NumFlrOff > 0) && ((split.index + 1) <= ((NumFlrsComm + NumFlrMix + NumFlrOff) - 1))): comp(f){side: Simple_Off | bottom: FloorBottom | top : Top } OffReporting MassReporting case ((split.index + 1) > (NumFlrsComm + NumFlrMix + NumFlrOff) - 1): comp(f){side: Simple_Res | bottom: FloorBottom | top : Top } ResReporting MassReporting else: NIL else: NIL Towers --> case xLength > zLength : split(x) {theLength/2 : Tower1 | ~1 : Tower2 } else : split(z) {(theLength/2) : Tower1 | ~1 : Tower2 } Tower1 --> setback(FSetbackT1) { street.front : Concrete | remainder : T1Sub1 } T1Sub1 --> setback(BSetbackT1) { street.back : Concrete | remainder : T1Sub2 } T1Sub2 --> setback(LSetbackT1) { street.left : Concrete | remainder : T1Sub3 } T1Sub3 --> setback(RSetbackT1) { street.right : Concrete | remainder : Tower1Extrude } Tower1Extrude --> extrude(world.y, (Tower1_Floors * Upperfloor_Height)) T1BuildingVolume3D T1BuildingVolume3D --> # the volume is split into upper floor volumes, as many times as possible ('*' sign) split(y) {~Upperfloor_Height : T1Volume}* T1Volume --> case (split.index <= (NumFlrComm1 - 1)): comp(f){side: Simple_Com | bottom: FloorBottom | top : Top } CommReporting MassReporting case ((split.index > (NumFlrComm1 - 1)) && (NumFlrMix1 > 0) && ((split.index) <= ((NumFlrComm1 + NumFlrMix1) - 1))): comp(f){side: Simple_Mix | bottom: FloorBottom | top : Top } MixReporting MassReporting case (((split.index) > ((NumFlrComm1 + NumFlrMix1) - 1)) && (NumFlrOff1 > 0) && ((split.index) <= ((NumFlrComm1 + NumFlrMix1 + NumFlrOff1) - 1))): comp(f){side: Simple_Off | bottom: FloorBottom | top : Top } OffReporting MassReporting case ((split.index) > (NumFlrComm1 + NumFlrMix1 + NumFlrOff1) - 1): else: comp(f){side: Simple_Res | bottom: FloorBottom | top : Top } ResReporting MassReporting else: NIL Tower2 --> setback(FSetbackT2) { street.front : Concrete | remainder : T2Sub1 } T2Sub1 --> setback(BSetbackT2) { street.back : Concrete | remainder : T2Sub2 } T2Sub2 --> setback(LSetbackT2) { street.left : Concrete | remainder : T2Sub3 } T2Sub3 --> setback(RSetbackT2) { street.right : Concrete | remainder : Tower2Extrude } Tower2Extrude --> extrude(world.y, (Tower2_Floors * Upperfloor_Height)) T2BuildingVolume3D T2BuildingVolume3D --> # the rest of the volume is not split into upper floor volumes, as many times as possible ('*' sign) split(y) {~Upperfloor_Height : T2Volume}* T2Volume --> case (split.index <= (NumFlrComm2 - 1)): comp(f){side: Simple_Com | bottom: FloorBottom | top : Top } CommReporting MassReporting case ((split.index > (NumFlrComm2 - 1)) && (NumFlrMix2 > 0) && ((split.index) <= ((NumFlrComm2 + NumFlrMix2) - 1))): comp(f){side: Simple_Mix | bottom: FloorBottom | top : Top } MixReporting MassReporting case (((split.index) > ((NumFlrComm2 + NumFlrMix2) - 1)) && (NumFlrOff2 > 0) && ((split.index) <= ((NumFlrComm2 + NumFlrMix2 + NumFlrOff2) - 1))): comp(f){side: Simple_Off | bottom: FloorBottom | top : Top } OffReporting MassReporting case ((split.index) > (NumFlrComm2 + NumFlrMix2 + NumFlrOff2) - 1): comp(f){side: Simple_Res | bottom: FloorBottom | top : Top } ResReporting MassReporting else: NIL Simple_Com --> color(ComColor) set(material.opacity,OpacityVal) Simple_Mix --> color(MixColor) set(material.opacity,OpacityVal) Simple_Off --> color(OffColor) set(material.opacity,OpacityVal) Simple_Res --> color(ResColor) set(material.opacity,OpacityVal)
