<?xml version="1.0" ?> <configuration> <description/> <taskurl>http://152.46.17.82/arcgis/rest/services/surf_city/Viewshed_Async/GPServer/Viewshed Analysis</taskurl> <helpurl>http://152.46.17.82/arcgis/rest/directories/arcgisoutput/surf_city/Viewshed_Async_GPServer/surf_city_Viewshed_Async/SCWebApp2.htm</helpurl> <autosubmit>false</autosubmit> <inputparams> <param type="string" name="Parcel Address" required="true" visible="true" label="Parcel Address" defaultvalue="hadd = '1 DIVISION AVE'" tooltip = "Select an address to run a viewshed analysis on"> <choicelist> <choice value = "1 DIVISION AVE"/> <choice value = "1 S 3RD ST"/> <choice value = "1017 N OCEAN AVE"/> </choicelist> </param> </inputparams> <outputparams> <param type="featurerecordset" name="vs_2005_int_shp" geometrytype="polygon" mode="drawtool" required="true" visible="true" label="2005 Viewshed"> <popup> <fields> <field name="FID" label="FID" visible="false"/> <field name="FID_buffer" label="FID_buffer" visible="false"/> <field name="id" label="Parcel ID" visible="true"/> <field name="centroid" label="X Coordinate" visible="true"/> <field name="y_centroid" label="Y Coordinate" visible="true"/> <field name="hadd" label="Parcel Address" visible="true"/> <field name="floors" label="Number of Floors" visible="true"/> <field name="spot" label="spot" visible="false"/> <field name="azimuth1" label="azimuth1" visible="false"/> <field name="azimuth2" label="azimuth2" visible="false"/> <field name="radius1" label="radius1" visible="false"/> <field name="radius2" label="radius2" visible="false"/> <field name="offseta" label="offseta" visible="false"/> <field name="BUFF_DIST" label="BUFF_DIST" visible="false"/> <field name="FID_vs_200" label="FID_vs_200" visible="false"/> <field name="ID_1" label="ID_1" visible="false"/> <field name="GRIDCODE" label="GRIDCODE" visible="false"/> <field name="Shape_Length" label="Shape_Length" visible="false"/> <field name="Shape_Area" label="Shape_Area" visible="false"/> </fields> <medias/> <showattachments>false</showattachments> <showrelatedrecords>false</showrelatedrecords> </popup> <renderer type="uniquevalue" attribute="GRIDCODE"> <infos> <symbol value="1" type="simplefill" alpha="0.5" color="0xCC0033"> <outline color="0x999999" width="1"/> </symbol> </infos> <defaultsymbol type="simplefill" alpha="0.5" color="0x000000"> <outline color="0x000000" width="1"/> </defaultsymbol> </renderer> </param> <param type="featurerecordset" name="vs_2010_int_shp" geometrytype="polygon" mode="drawtool" required="true" visible="true" label="2010 Viewshed"> <popup> <fields> <field name="FID" label="FID" visible="false"/> <field name="FID_vs_201" label="FID_vs_201" visible="false"/> <field name="ID" label="ID" visible="true"/> <field name="GRIDCODE" label="GRIDCODE" visible="false"/> <field name="FID_buffer" label="FID_buffer" visible="false"/> <field name="id_1" label="id_1" visible="true"/> <field name="centroid" label="centroid" visible="true"/> <field name="y_centroid" label="y_centroid" visible="true"/> <field name="hadd" label="hadd" visible="true"/> <field name="floors" label="floors" visible="true"/> <field name="spot" label="spot" visible="false"/> <field name="azimuth1" label="azimuth1" visible="false"/> <field name="azimuth2" label="azimuth2" visible="true"/> <field name="radius1" label="radius1" visible="false"/> <field name="radius2" label="radius2" visible="false"/> <field name="offseta" label="offseta" visible="false"/> <field name="BUFF_DIST" label="BUFF_DIST" visible="false"/> <field name="Shape_Length" label="Shape_Length" visible="false"/> <field name="Shape_Area" label="Shape_Area" visible="false"/> </fields> <medias/> <showattachments>false</showattachments> <showrelatedrecords>false</showrelatedrecords> </popup> <renderer type="uniquevalue" attribute="GRIDCODE"> <infos> <symbol value="1" type="simplefill" alpha="0.5" color="0x0099FF"> <outline color="0x999999" width="2"/> </symbol> </infos> <defaultsymbol type="simplefill" alpha="0.1" color="0x000000"> <outline color="0x000000" width="1"/> </defaultsymbol> </renderer> </param> <param type="featurerecordset" name="select_point_shp" geometrytype="point" mode="drawtool" required="true" visible="true" label="Selected Home"> <popup> <fields> <field name="FID" label="FID" visible="false"/> <field name="id" label="id" visible="true"/> <field name="centroid" label="centroid" visible="false"/> <field name="y_centroid" label="y_centroid" visible="false"/> <field name="hadd" label="hadd" visible="true"/> <field name="floors" label="floors" visible="false"/> <field name="spot" label="spot" visible="false"/> <field name="azimuth1" label="azimuth1" visible="false"/> <field name="azimuth2" label="azimuth2" visible="false"/> <field name="radius1" label="radius1" visible="false"/> <field name="radius2" label="radius2" visible="false"/> <field name="offseta" label="offseta" visible="false"/> </fields> <medias/> <showattachments>false</showattachments> <showrelatedrecords>false</showrelatedrecords> </popup> <renderer type="simple"> <defaultsymbol type="simplemarker" alpha="0.5" color="0xFFFF00" size="15"> <outline color="0x000000" width="1"/> </defaultsymbol> </renderer> </param> </outputparams> <layerorder>select_point_shp,vs_2010_int_shp,vs_2005_int_shp</layerorder> </configuration>
