We have integrated ESRI with ADFS for token based authentication. I am looking for .NET- UWP application code to access ERSI secured map with ADFS token without user login screen. Application should access secured map without asking user login credentials.
Not sure what your actual question is....
But basically wherever you are supposed to pass a username and password to get a credential pass in empty strings. This tells the API to use IWA.
