Hi All
I am having an issue with Calcite maps Javascript and the 4.x LayerList widget using Android Chrome. It seems that when the layer list widget has selectionEnabled: true - I am unable to turn the layers on/off and/or expand the layers in the widget. I can reorder the layers without issue however. This only seems to happen when the view is small as on a phone...it works fine when using a desktop browser.
Any ideas?
Thanks!
Update: we will have this fixed for the Spring release (4.15), and the update should be available now on js-next. Thank you again for reporting this issue. This sneak-peak app should work as expected:
https://codepen.io/noash/pen/eYNpKLN
Great! Thanks Noah! I look forward to hearing about a solution (or a temp work-around).
Mike
Gotcha. I can reproduce the issue now. Thanks for reporting this. We'll investigate and I'll update this thread when there is something to share.
Hi Noah,
Yes it works fine for me too on a Pixel 2 with default functionality, but, the same sample above and adding 'selectionEnabled: true' to the LayerList will not allow turning on/off layers or expanding the layers. Reordering the layers works just fine however. The 'selectionEnabled: true' property is the issue. And it appears that it has nothing to do with Calcite.
Hi Michael, could you provide some more information to reproduce the issue? Specifically, a link to a sample that you used, and the type and version of the Android device.
I tested with this sample:
LayerList widget - 4.14
On a Samsung Galaxy s8 with Chrome, and it worked fine.
