When working with numeric fields in the App (float, long or short integer for instance..) it seems you can not have a field open as empty by default, it is always populated by a value. This is fine where a range is set but otherwise it can mean a lot more time in the field as the process of deleting and re-entering a value is time consuming. Is it not possible to have an empty numeric field by default ? I am aware that text fields can be empty by default on opening.
Thanks, Francis.
