require([ "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend","esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/_base/array", "dojo/parser", "esri/dijit/LocateButton", "esri/dijit/HomeButton", "esri/dijit/OverviewMap", "esri/layers/ArcGISDynamicMapServiceLayer", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane","dijit/layout/AccordionContainer", "dojo/domReady!" ], function( Map, FeatureLayer, Legend,BasemapGallery, arcgisUtils, arrayUtils, parser , LocateButton, HomeButton, OverviewMap, ArcGISDynamicMapServiceLayer )
map.on("layers-add-result", function (evt) { buildLayerList(evt) }); function buildLayerList(evt) { array.forEach(evt.layers, function (layer) { var vis = []; visible.push(vis); buildCheckboxes(layer); }); } function buildCheckboxes(layer) { array.forEach(layer.layer.layerInfos, function (info, index) { var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id + info.id, value: layer.layer.id + "_" + info.id, checked: info.defaultVisibility, onChange: function (evt) { var thisArray = this.value.split("_") var layerID = thisArray[0]; var infoID = parseInt(thisArray[1]); var clayer = map.getLayer(thisArray[0]); var visArray = clayer.visibleLayers; var ind = visArray.indexOf(infoID); if (ind > -1) { visArray.splice(ind, 1); } else { visArray.push(infoID); } if (visArray.length == 0) { visArray.push(-1);} clayer.setVisibleLayers(visArray); } });
layers = dojo.queryToObject(URLparams).layers; layerList = (layers) ? layers.split(',') : []; for (a in layerList ) { layerList = parseInt(layerList); }
if (layer.loaded) { buildLayerList(layer); } else { dojo.connect(layer, "onLoad", buildLayerList); }
<!doctype html> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>RssToggle</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { height: 100%; margin: 0; padding: 0; } #metaLegend { position: absolute; left: 20px; bottom: 20px; width: 20em; height: 5em; z-index: 40; background: #fff; color: #777; padding: 5px; border: 2px solid #666; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; font-family: arial; font-size: 0.9em; } #metaLegend h3 { color: #666; font-size: 1.1em; padding: 0px; margin: 0px; display: inline-block; } #metac { position: absolute; left: 20px; bottom: 20px; width: 20em; height: 5em; z-index: 40; background: #fff; color: #777; padding: 5px; border: 2px solid #666; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; font-family: arial; font-size: 0.9em; } #metac h3 { color: #666; font-size: 1.1em; padding: 0px; margin: 0px; display: inline-block; } legendDiv { display:none;} </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/layers/KMLLayer", "esri/layers/GeoRSSLayer", "esri/InfoTemplate", "dojo/parser", "esri/layers/FeatureLayer", "dojo/_base/array", "esri/symbols/PictureMarkerSymbol", "esri/renderers/SimpleRenderer", "esri/dijit/Legend", "dijit/form/CheckBox","dojo/dom", "dojo/dom-construct", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, KMLLayer, GeoRSSLayer, InfoTemplate, parser, FeatureLayer,array, PictureMarkerSymbol, SimpleRenderer, Legend,CheckBox, dom, domConstruct ) { map = new esri.Map("map",{ basemap: "oceans", center: [-122.399, 37.78], zoom: 9 }); // create layout dijits parser.parse(); var kmlUrl = "http://dl.dropbox.com/u/2654618/kml/Wyoming.kml"; var kml = new KMLLayer(kmlUrl); var cities = new FeatureLayer( "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0", { mode: FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); // var georssUrl = "http://geocommons.com/overlays/116926.atom"; // S.F. and East Bay Breweries http://geocommons.com/overlays/116926 var georss = new GeoRSSLayer("http://geocommons.com/overlays/116926.atom"); georss.on("load", function() { //domStyle.set("loading", "display", "none"); // create an info template var template = new InfoTemplate("${address}", "${zip}"); // set the info template for the feature layers that make up the GeoRSS layer // the GeoRSS layer contains one feature layer for each geometry type var layers = georss.getFeatureLayers(); var picRenderer = new PictureMarkerSymbol("http://static.arcgis.com/images/Symbols/Basic/RedShinyPin.png", 21, 21); var georssRenderer = new SimpleRenderer(picRenderer); array.forEach(layers, function(l) { l.setInfoTemplate(template); l.setRenderer(georssRenderer) }); }); /////////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////////////////// //add the legend map.on("layers-add-result", function (evt) { var layerInfo = array.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } //add check boxes array.forEach(layerInfo, function (layer) { var layerName = layer.title; var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id, value: layer.layer.id, checked: layer.layer.visible, onChange: function (evt) { var clayer = map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; } }); //add the check box and label to the TOC domConstruct.place(checkBox.domNode, "toggle", "after"); var checkLabel = domConstruct.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after"); domConstruct.place("<br />", checkLabel, "after"); }); }); map.addLayers([georss,cities, kml]); }); </script> </head> <body class="tundra"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="metaLegend"style="display: none;"> <h3>Legend</h3> <br> <div id="legendDiv"></div> </div> <div id="metac"> <h3>Layers</h3> <br> <div id="toggle" style="padding: 2px 2px;"></div> </div> </div> </div> </div> </body> </html>
<!doctype html> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>RssToggle</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { height: 100%; margin: 0; padding: 0; } #metaLegend { position: absolute; left: 20px; bottom: 20px; width: 20em; height: 5em; z-index: 40; background: #fff; color: #777; padding: 5px; border: 2px solid #666; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; font-family: arial; font-size: 0.9em; } #metaLegend h3 { color: #666; font-size: 1.1em; padding: 0px; margin: 0px; display: inline-block; } #metac { position: absolute; left: 20px; bottom: 20px; width: 20em; height: 5em; z-index: 40; background: #fff; color: #777; padding: 5px; border: 2px solid #666; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; font-family: arial; font-size: 0.9em; } #metac h3 { color: #666; font-size: 1.1em; padding: 0px; margin: 0px; display: inline-block; } legendDiv { display: none; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/layers/KMLLayer", "esri/layers/GeoRSSLayer", "esri/InfoTemplate", "dojo/parser", "esri/layers/FeatureLayer", "dojo/_base/array", "esri/symbols/PictureMarkerSymbol", "esri/renderers/SimpleRenderer", "esri/dijit/Legend", "dijit/form/CheckBox", "dojo/dom", "dojo/dom-construct", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( Map, KMLLayer, GeoRSSLayer, InfoTemplate, parser, FeatureLayer, array, PictureMarkerSymbol, SimpleRenderer, Legend, CheckBox, dom, domConstruct ) { map = new esri.Map("map", { basemap: "oceans", center: [-122.399, 37.78], zoom: 9 }); // create layout dijits parser.parse(); var kmlUrl = "http://dl.dropbox.com/u/2654618/kml/Wyoming.kml"; var kml = new KMLLayer(kmlUrl, { id: "KML" }); var cities = new FeatureLayer( "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0", { mode: FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); // var georssUrl = "http://geocommons.com/overlays/116926.atom"; // S.F. and East Bay Breweries http://geocommons.com/overlays/116926 var georss = new GeoRSSLayer("http://geocommons.com/overlays/116926.atom"); georss.on("load", function () { //domStyle.set("loading", "display", "none"); // create an info template var template = new InfoTemplate("${address}", "${zip}"); // set the info template for the feature layers that make up the GeoRSS layer // the GeoRSS layer contains one feature layer for each geometry type var layers = georss.getFeatureLayers(); var picRenderer = new PictureMarkerSymbol("http://static.arcgis.com/images/Symbols/Basic/RedShinyPin.png", 21, 21); var georssRenderer = new SimpleRenderer(picRenderer); array.forEach(layers, function (l) { l.setInfoTemplate(template); l.setRenderer(georssRenderer) }); }); /////////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////////////////// //add the legend map.on("layers-add-result", function (evt) { var layerInfo = array.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } //add check boxes array.forEach(layerInfo, function (layer) { var layerName = layer.title; if (layer.layer.id === "KML") { layerName = "KML Layer";} var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id, value: layer.layer.id, checked: layer.layer.visible, onChange: function (evt) { var clayer = map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; } }); //add the check box and label to the TOC domConstruct.place(checkBox.domNode, "toggle", "after"); var checkLabel = domConstruct.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after"); domConstruct.place("<br />", checkLabel, "after"); }); }); map.addLayers([georss, cities, kml]); }); </script> </head> <body class="tundra"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="metaLegend" style="display: none;"> <h3>Legend</h3> <br> <div id="legendDiv"></div> </div> <div id="metac"> <h3>Layers</h3> <br> <div id="toggle" style="padding: 2px 2px;"></div> </div> </div> </div> </div> </body> </html>
I have a similar question to all of this. i have several table of contents that are grouped by types of data. The client wants a separate legend that they can open and see a list of layers that are checked in the other TOCs and be able to check the layers in the new TOC for identifying. Here is a screenshot of what i have so far:
The bottom left is the new TOC that i want to just list visible layers that are turned on elsewhere. Thanks!
p.s. i know its redundant but that's what they want!
Les membres connectés peuvent publier, suivre les mises à jour et bien plus encore. Vous êtes nouveau ici ? Créez un compte gratuit.
