Coding gurus,I've got a question about best practise when using the ComReleaser object. In the first example below is some stub code showing how I would typically using ComReleaser when I'm processing within a single loop.Using comRel As New ComReleaser() pFeatureCursor = pFeatureClass.Update(pQueryFilter, False) comRel.ManageLifetime(pFeatureCursor) pFeature = pFeatureCursor.NextFeature Do While Not pFeature Is Nothing ' Do something pFeatureCursor.UpdateFeature(pFeature) pFeature = pFeatureCursor.NextFeature Loop pFeatureCursor.Flush() End Using
Now suppose I want to loop through another cursor whilst looping through the first cursor, so nested. Is it appropriate to have a Using statement within a using statement (1) or do you simply add the inner cursor to the comReleaser object (2). I ask as I've not seen any examples and was wondering what was the best approach when nesting cursors?Example 1
Using comRel As New ComReleaser() pFeatureCursor = pFeatureClass.Update(pQueryFilter, False) comRel.ManageLifetime(pFeatureCursor) pFeature = pFeatureCursor.NextFeature Do While Not pFeature Is Nothing ' Do something Using comRel2 as New ComReleaser() pFeatureCursor2 = pFeatureClass2.Search(pQueryFilter2, False) comRel2.ManageLifetime(pFeatureCursor2) ' Do something inner looping stuff End Using pFeatureCursor.UpdateFeature(pFeature) pFeature = pFeatureCursor.NextFeature Loop pFeatureCursor.Flush() End Using
Example 2
Using comRel As New ComReleaser() pFeatureCursor = pFeatureClass.Update(pQueryFilter, False) comRel.ManageLifetime(pFeatureCursor) pFeature = pFeatureCursor.NextFeature Do While Not pFeature Is Nothing ' Do something pFeatureCursor2 = pFeatureClass2.Search(pQueryFilter2, False) comRel.ManageLifetime(pFeatureCursor2) ' Do something inner looping stuff End Using pFeatureCursor.UpdateFeature(pFeature) pFeature = pFeatureCursor.NextFeature Loop pFeatureCursor.Flush() End Using
In example 2 pFeatureCursor2 is added to comRel on every cycle of the outer cursor loop, is that good, bad or irrelevant?
