Hi all--
After creating about 90 maps using Kriging in the Spatial Analyst tool, I found that it created different legends based on the minimum and maximum values. In order to see compare what is spatially happening, and analyzing minimum and maximum values of all the maps, I have calculated a standard binning number and the specific ranges.
I have tried using the symbology tab and redefining the ranges, and found that that doesn't change the value at each point. Because all of the values are all less than 1, I also found I cannot use the Reclassify tool. Is there a tool or method that can be used for changing 9 ranges into 20 ranges and can be in a more precise data type, and preferably have a batching method?
Samantha
