I get an error when using a Python expression in the field calculator in ArcGIS 10 using ArcObjects. The expression works fine when using the GUI.I can't see where to set the parser to Python instead of VBScript using ICalculator.I am using .NET, but made this simple VBA routine for testing, where it updates the last field with the logp of the field named SumOfConcentrations
Public Sub TestPythonCalc()
Dim fc As IFeatureClass
Set fc = GetLayer0.FeatureClass
Dim calc As ICalculator
Set calc = New Calculator
With calc
Set .Cursor = fc.Update(Nothing, False)
.Expression = "math.log1p(!SumOfConcentrations!)"
.Field = fc.Fields.Field(fc.Fields.FieldCount - 1).Name
.ShowErrorPrompt = False
.Calculate
End With
End Sub
Private Function GetLayer0() As IGeoFeatureLayer
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pGFL As IGeoFeatureLayer
Set pGFL = pMxDoc.FocusMap.Layer(0)
Set GetLayer0 = pGFL
End Function
