I would like to join the Live Stream Gauges layer to hosted feature layer I have published named Areas of Interest. I have identified Polygon Areas of Interest that can be join to the Living Atlas layer via StationID.I have made my join but it looks like once I joined the layers it is static and no longer pulls in the Live Stream Guage updates from NOAA. I also attempted this in Arcade but while I can get the Pop Ups to provide infromation by accessing featuresets I can't use it to Symbolize.
Any ideas?
Stefani
Hi Stefani,
Here is a reply from our product engineer:
You cannot join two tables in a dynamic join unless they are in the same Database or Hosted Feature Service in this case. Joining a Feature Layer and a Table Layer in the same Hosted Feature Service is possible, but not from two different services.
The Arcade expression works because it performs a query to the Stream Gauges service to get the related rows.
HI Caitlin,
Is there a way to symbolize my layer based on the height field from the Live Stream Gauges layer with Arcade? Basically, if the stream gauge layer gets to a certain height (pulled from a field in my layer), then turn my polygon a different color?
This is something that GeoEvent Extension can do. Using the Polygons as a GeoFence, it could identify the Stream Gauges inside the Fence line and check for an elevated Stage height and take some action. But as far as I know, not Arcade. Good luck!
Caitlin and Paul
Hi Caitlin,
I was able to solve this using Pandas and the Python API. Th California Nevada River Forecast Center puts out an online XML that is updated every 5 minutes. I was able to parse this xml:
https://www.cnrfc.noaa.gov/data/kml/riverFcst.xml? into a Pandas DataFrame. From there I added an empty field to my polygon layer hold the current water height from thier stream gauges(same as NOAA). I then turned my hosted feature layer into a spatial dataframe, jointed to the live stream gauge df I created and calced in the current river height to my polygon layer. I have this set up to run every so often to keep the data current. Its not the Living Atlas or Arcade solution I wanted, but it works like a charm.
I do have some questions about the GeoEvent Extension though. Is this different from a GeoEvent server? Which liscenses include this extension? Does it cost credits?
I feel like my company could defietly benefit from this technology.
Thanks!
