Hi all
im using maplex engine for my labeling feature, when i see in the layout view i can see the label workd
but when i export it to the pdf my label doesnt show up..
its only show my feature
does anyone know how to fix this problem?
thanks
sent it to your email Mr Pattan..
thanks again for helping
Hi Rudini Rudini
I have gone through your Map Package. But, No Labeling has been done in the map. I would really appreciate it if you could enable labeling and send it again so that I can export it as a PDF right away.
Hi Imran Khan Pattan thanks for answer my question.
im using arcgis ver 10.6
the map package will sent to your PM..
Hello Rudini Rudini
What version of ArcMap are you using?
I have followed the same workflow as you have mentioned and I am able to export the PDF without loosing any labeling.
Is it possible for you to provide the Map Package so that I can check the issue?
