I download the source code of Flex Viewer 3.6 and input it to Flash builder. After reading the following post from ESRI, I realize the config file of GeoprocessingWidget.xml does not even exist, then how do we set the widget? Thanks!
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Geoprocessing_widget_tags/01m30000002s000000/
The set up codes in main config.xml is as the following:
<widget label="Geoprocessing" left="10" top="400" icon="assets/images/GeoprocessingTool48.png" config="widgets/Geoprocessing/GeoprocessingWidget.xml" url="widgets/Geoprocessing/GeoprocessingWidget.swf"/>
Lei,
Most people either just create the XML themselves or use App Builder to configure the widget.
Here is a sample:
<?xml version="1.0"?> <configuration label="Drive time analysis"> <taskurl>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Network/ESRI_DriveTime_US/GPServer/CreateDriveTimePolygons</taskurl> <helpurl>http://sampleserver1.arcgisonline.com/arcgisoutput/Network_ESRI_DriveTime_US/CreateDriveTimePolygons.htm</helpurl> <inputparams> <param name="Input_Location" geometrytype="point" label="Start location" required="true" type="featurerecordset" visible="true"> <simplerenderer> <simplemarkersymbol color="0xBEEFEE" size="15"> <outline width="2" color="0x00AADD"/> </simplemarkersymbol> </simplerenderer> </param> <param name="Drive_Times" defaultvalue="5 10 15" label="Drive times" required="false" type="string" visible="false"/> </inputparams> <outputparams> <param name="Output_Drive_Time_Polygons" geometrytype="polygon" label="Output Drive Time Polygons" required="true" type="featurerecordset" visible="true"> <popup> <title>{Name}</title> <fields> <field name="FromBreak" alias="From Break" visible="true"/> <field name="ToBreak" alias="To Break" visible="true"/> </fields> </popup> <uniquevaluerenderer field="ToBreak"> <simplefillsymbol alpha="0.5" color="0xFF00FF"> <outline color="0x000000"/> </simplefillsymbol> <uniquevalueinfo value="5"> <simplefillsymbol color="0xFF0000"> <outline color="0x000000"/> </simplefillsymbol> </uniquevalueinfo> <uniquevalueinfo value="10"> <simplefillsymbol color="0x00FF00"> <outline color="0x000000"/> </simplefillsymbol> </uniquevalueinfo> <uniquevalueinfo value="15"> <simplefillsymbol color="0x0000FF"> <outline color="0x000000"/> </simplefillsymbol> </uniquevalueinfo> </uniquevaluerenderer> </param> </outputparams> <layerorder>Input_Location,Output_Drive_Time_Polygons</layerorder> </configuration> <!-- See Geoprocessing widget tag reference at http://links.esri.com/geoprocessingwidget -->
Thanks a lot!
