The problem is that when I use Shift tool on a raster, it doesn't get shifted no matter what distance values do I input. This happens when I set Output Raster Dataset to my custom location (inside Folder Connections). If I leave it default (Default.gdb), it gets moved properly. Why is it so? I would really like to avoid saving it do default GDB and then opening it and saving somewhere else.
The raster is RGB composition straight from Landsat bands from Earth Explorer.
I use ArcMap 10.4.1.5686, I have background geoprocessing disabled.
Geoprocessing results windows shows everything is fine.
The tool is inside Data Management Tools -> Projections and Transformations -> Raster.
Any help will be appreciated.
Best regards,
Adam
