rows = arcpy.UpdateCursor("Assets") for row in rows: if row.Processed == "N" and row.Asset_ID == "Asset_Unprocessed.Asset_ID": row.Processed = "Y" rows.updateRow(row) del row del rows
table = 'assets_unprocessed' assetIDList = [] rows = arcpy.SearchCursor(table) for row in rows: assetIDList.append(row.Asset_ID) del row, rows table2 = 'assets' for ID in assetIDList: rows = arcpy.UpdateCursor(table2) for row in rows: if row.Asset_ID == ID: row.Processed = 'Y' rows.updateRow(row) del row, rows print 'finished'
import arcpy from arcpy import env import datetime import os env.workspace = "c:\Users\matt\Desktop\Projects\Assets\Assets.mdb" #Make a TableView of Non-Spatial Asset records that need to be processed arcpy.MakeQueryTable_management (["Assets"], "Asset_Line", "ADD_VIRTUAL_KEY_FIELD", "",[["Asset_ID"], ["Ditch_ID"], ["Begin_Station"], ["End_Station"]], "[Assets.Processed] <> 'Y'") #Add queried data to Assets_Unprocessed table-to be used by ArcObjects utility to create spatial features arcpy.Append_management ("Asset_Line", "Assets_Unprocessed") #Copy attribute data to spatial Asset features #Call ArcObjects utility to snap 'out of ditch' linear features to spatial Asset features #Call ArcObjects utility to snap related assets to spatial Asset features au = "Assets_Unprocessed" lstIds = [] fld = "Asset_ID" auRows = arcpy.SearchCursor(au) for row in auRows: lstIds.append(row.Asset_ID) del row, auRows table2 = "Assets" for ID in lstIds: rows = arcpy.UpdateCursor(table2) for row in rows: if row.Asset_ID == ID: row.Processed = 'Y' rows.updateRow(row)
The latest reply mentioned using a SearchCursor without the with...as statement, but I cannot get that to work either (error returns 'Cursor' object has no attribute 'Asset_ID' when I run the SearchCursor code:
au = "Assets_Unprocessed" lstIds = [] fld = "Asset_ID" auRows = arcpy.SearchCursor(au) for row in auRows: lstIds.append(auRows.Asset_ID)
Greg,Thanks for the input, I see how that could resolve my issue. I tried running that SearchCursor section of code you supplied, but an error was returned: Runtime error <type 'exceptions.AttributeError'>: 'Cursor' object has no attribute '__exit__'I am unfamiliar with the with...as statement so I'm not sure what is missing or needed here. I understand the process of building a list of Asset_ID's from Assets_Unprocessed then searching for records in Assets with those Asset_ID's, but it seems I'm having difficulty in first building that list with the SearchCursor and the use of the with...as statement.
au = "Assets_Unprocessed" fld = "Asset_ID" lstIds = [] auRows = arcpy.SearchCursor(au) for row in auRows: lstIds.append(auRows.Asset_ID) del auRows del row try: aRows = arcpy.UpdateCursor("Assets") for row in aRows: if row.Processed == "N" and row.Asset_ID in lstIds: row.Processed = "Y" aRows.update(row) except Exception as e: print e.message #do whatever del aRows del row
