I changed the arcgis-js api version from 3.14 to 3.18.
This is because the alias has not changed in 3.14.
But I faced one problem.
In 3.18, the feature table did not work when there was a lot of data.
I have compared the parameters of both.
.14>
http://localhost:8080/iOpenAPI/AGS/rest/services/CadastralMap/MapServer/13/query?f=json&returnIdsOnly=false&where=1%3D1&…
.18>
http://localhost:8080/iOpenAPI/AGS/rest/services/CadastralMap/MapServer/13/query?f=json&returnIdsOnly=true&where=1%3D1&…
The value of returnIdsOnly was different.
So I tried to change this parameter but I could not find a way.
How can I change this parameter?
Or how can I show a lot of data in the feature table?
this is my code.
if(map.getLayer('FeatureTableLayer')) map.removeLayer(map.getLayer('FeatureTableLayer'));
if(krcgis.core.EventList['table.add']) krcgis.core.EventList['table.add'].remove(); //다른 레이어 선택시 중복 이벤트 제거.
var result_layer_list = [];
var selectLayerInfos = [];
if (!this.cboLayer.item) {
return;
var url = selectService.url + '/' + this.cboLayer.item.LYR_ID;
selectLayer = new FeatureLayer(url, {
mode: FeatureLayer.MODE_ONDEMAND, //여기를 좀 다른걸로 줘서 테스트해바바
// mode: FeatureLayer.MODE_SELECTION,
outFields: ["*"],
visible: false,
if (!selectLayer) {
return; //피처 레이어 객체가 생성되지 않았을 경우.
if (this.InfoGrid) {
//console.log('infoGrid after create..', this.InfoGrid);
//infoGrid.destroyRecursive(true);
this.InfoGrid.destroy();
map.addLayer(selectLayer);
krcgis.core.EventList['table.add'] = map.on('layer-add',lang.hitch(this,function(e){
for(var key in e.layer.fields){
selectLayerInfos.push(e.layer.fields[key].name);
krcgis.Function.Dictionary.getList("FIELD",selectLayerInfos, lang.hitch(this,function(json){
for (var i=0 ; i<selectLayerInfos.length ; i++) {
var ename = selectLayerInfos;
var kname = ename;
if(json[ename]) kname = json[ename];
var result_layer_data = {
alias: kname
result_layer_list.push(result_layer_data);
this.InfoGrid.fieldInfos = result_layer_list;
this.InfoGrid.featureLayer.name = this.cboLayer.item.LYR_NM;
this.InfoGrid.startup();
var _div = dojo.place('<div id="_TableWidgetOnInfoGrid" style="width:100%;height:100%;"></div>', cpC.domNode);
this.InfoGrid = new FeatureTable({
featureLayer : selectLayer
}, _div.id);
