Hello all,Has anyone had success with the geocoderOptions parameter in the Directions dijit constructor? I configured the object as I do when I use the geocoder dijit, i.e. provide a suffix, search extent, etc. When I use that parameter in the constructor, the origin - destination input elements behave as geocoders. In other words, on entering the from - to strings, the map geocodes the addresses (individually) but doesn't provide directions.What am I missing?This works :
var routeUrl = "my routing service url";
var directions = new esri.dijit.Directions({
map: map,
routeTaskUrl: routeUrl,
routeParams: {
directionsLanguage: "en-US"
}, "directionsPanel");
directions.startup();
This doesn't :
var searchExtent = new esri.geometry.Extent({
"xmin": -13725568.18,
"ymin": 5669639.97,
"xmax": -13587981.53,
"ymax": 5761364.41,
"spatialReference": {
"wkid": 102100
var geocoderOptions = {
autoComplete: true,
arcgisGeocoder: {
url: "http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer",
name: "Esri World Geocoder",
suffix: " Portland, OR",
searchExtent: searchExtent,
sourceCountry: "USA"
var routeUrl = "my route service url";
map: map,
geocoderOptions: geocoderOptions,
routeParams: {
Thanks for the help! I can provide a repo case via link or JSFiddle if anyone is interested.Cheers.- d
