Hi. I'd like to know if it is possible to find optimal location with the location-allocation tool in ArcGIS Pro if I don't have any candidate points?
I do a research for potential locations of mobility hubs where the big hubs are located closed close to subway and train stations (I used a weighted analysis to find these locations). Now I would like to determine the small stations which should lay between those big hubs. As an influence value I want to use the population density.
Thank you.
