I'm using the Interoperability Extension 'quick import' to subset and convert an OpenStreetMap .xml file. I setup the conversion parameters and ran the tool, about two hours into the process an error occurred:
NULL pointer check failed. File: geodbfeatureclass.cpp Line #: 1010
Some features (all points) were converted but not the remainder. I've attached the complete log file. Running ArcGIS 10.3.1 on Windows Server 2008 r2.
Anyone have any ideas why the process is failing? Unfortunately, I have no other way to convert the data right now.
Cheers,
Greg
