Hi there,
I am new at Pythin and during the last couple months I have working on writing some Python scripts to automatize some of my drone imagery analysis, such as the code bellow. I have written few scripts and used them on different datasets and they were working just fine. A couple days ago I realize that would be better to save my final raster (yellow) on the same folder that my original RGB raster (blue), so I can use that same path in other scripts for further analysis without having to copy rasters around. Then, I started to get a message ERROR 999998: Unexpected Error, and now does not matter which code I try to run, I get the same message.
I have been looking around for a solution for my issue but I have been unsuccessful on that regard. By reading some material online, it seems that problem is related to memory issues, but I am not quite sure about that. Here are some details about my machine and software.
- desktop computer (Windows 10, version 1511, OS Build 10586.663, Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz, RAM 32GB, System type 64-bit operating system, x64-based processor) . I have ArcGis 10.5 and I am using PythonWin (PythonWin 2.7.12 (v2.7.12:d33e0cf91556, Jun 27 2016, 15:19:22) [MSC v.1500 32 bit (Intel)] on win32.) to write my scripts.
- I ran the code bellow on my Surface 3 laptop (Windows 10 Pro, version 10.0.16299 build 16299, system type x64-based PC, processor Intel Core i5-4300 CPU @ 1.90GHz, 2501 Mhz, 2 cores, 4 logical processors; RAM 8GB) this morning and it worked just fine.
-Last night I ran the same code from within ArcGIS and it worked just fine.
-I can not understand how everything was working just fine until a couple days ago, and suddenly the computer does not have enough memory to handle the same task. My RGB file is (around 1.8 GB in size, but I used files larger than that in the past with no problems.
Any help to fix this issue would be greatly appreciated.
Code:
import arcpy, string, os, errno
from arcpy import env
from arcpy.sa import*
from datetime import datetime
arcpy.CheckOutExtension("spatial")
start_time = datetime.now()
imagery = r'E:\UAV2017\PythonField8ExGr\Field8_90ft_08012017.tif'
path = os.path.dirname(imagery)
base1 = os.path.basename(imagery)
base = os.path.splitext(base1)[0]
folder = "Results"
Results = os.path.join(path,folder)
if not os.path.exists(Results):
os.makedirs(Results)
print "Results folder successfully created"
exgr_filename = base + "_ExGr.tif"
arcpy.env.workspace = imagery
bands = [Raster(os.path.join(imagery, b)) for b in arcpy.ListRasters()]
print bands
arcpy.env.workspace = Results
Ngreen = (Float(bands[1])) / (Float(bands[0]) + bands[1] + bands[2])
Nred = (Float(bands[0])) / (Float(bands[0]) + bands[1] + bands[2])
Nblue = (Float(bands[2])) / (Float(bands[0]) + bands[1] + bands[2])
exgr = (2 * Ngreen) - Nred - Nblue
exgr.save(exgr_filename)
print "Excess Green successfully calculated"
#Build pyramids and calculate statistics
arcpy.BuildPyramids_management(exgr_filename)
print "Pyramids and Statistics successful"
end_time = datetime.now()
print('Duration: {}'.format(end_time - start_time))
Interactive Window messages:
File "C:\Python27\ArcGIS10.5\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
exec codeObject in __main__.__dict__
File "C:\Users\Paulo.Flores\Desktop\Python Codes\New versions\ExGr_calc_02072018.py", line 45, in <module>
RuntimeError: ERROR 999998: Unexpected Error.
