I am using ArcMap 10.4.1.
I want to manually calculate the transformation (WKID 1515) using the values from the Transformation Tables. I am familiar with matrices and can easily apply the 3 or 7 parameter method. I believe what ESRI is describing as the "Position Vector" method would use the matrices formulation. However, the WKID 1515 is only given as a "Coordinate Frame" method. Can I assume the dx, dy, dz...values tabulated for the Coordinate Frame method could also be used in the matrices formulation to solve the transformation ? If not, does ESRI have the tabulated parameters for the other methods ?
