Hi All
There seems to be a few questions about this on the Forums but no definitive answer.
In one of our Collector applications when users try to sync back to the server they are suddenly getting an error stating that:
A Replica with this GUID doesn't exist on the server.
Server logs show this:
| Replica with GUID ({B2AFEACE-4DFF-4C93-BF9E-059400757FB5}) does not exists on the server. |
And
Error: The item was not found. Failure to access the DBMS server [ORA-03114: not connected to ORACLE] [SDE.GDB_Items]. The item was not found. Failure to access the DBMS server [ORA-03114: not connected to ORACLE] [SDE.GDB_Items]. The item was not found. Failure to access the DBMS server [ORA-03114: not connected to ORACLE] [SDE.GDB_Items]. |
Interestingly though the sync does actual appear to be working, edits on the device are going back to the database and additions made to the 'master' data are being synced back to the device.
Hoping that someone has a solution or answer to this.
Cheers, Chris
