<head> <meta name="viewport" content="initial-scale=1.0, user-scalable=no, width=device-width" /> <meta http-equiv="Content-type" content="text/html; charset=utf-8" /> <title>GOinfra Inspection</title> <script> var dojoConfig = { //Required if you have dojo widgets (aka.dijits) in your HTML markup parseOnLoad: true }; </script> <!-- ArcGIS API for JavaScript 2.7, compact build (includes Dojo 1.6.1 but does not include all Dojo Widgets) --> <link href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/esri/dijit/css/Popup.css"/> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.7compact" type="text/javascript"></script> <!-- Our ArcGIS API for JavaScript 2.7 Dojo includes - see readme.txt --> <script type="text/javascript"> dojo.require("dojo.parser"); // Required if you have dojo widgets (aka. dijits) in your HTML markup dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.Popup"); dojo.require("esri.dijit.InfoWindowLite"); dojo.require("esri.virtualearth.VETiledLayer"); // For Bing Maps //dojo.require("esri.tasks._task"); dojo.require("esri.tasks.geometry"); </script> <!-- jQuery 1.7.1 --> <script src="jQuery/jquery-1.7.1.js"></script> <!-- jQuery UI 1.8.18 - only the position helper functions, the rest is not included --> <link rel="stylesheet" href="jQuery/jQueryUI/jquery-ui-1.8.18.custom.css" /> <script type="text/javascript" charset="utf-8" src="jQuery/jQueryUI/jquery-ui-1.8.18.custom.min.js"></script> <!-- jQuery Mobile 1.1.0-RC1 --> <link rel="stylesheet" href="jQuery/jquery.mobile-1.1.0-rc.1.css" /> <link rel="stylesheet" href="jQuery/jquery-mobile-custom.css" /> <!-- [YB 2012/02/29 We can use this file to modify the default css of jQuery Mobile] --> <script src="jQuery/jquery.mobile-1.1.0-rc.1.js"></script> <script src="jQuery/jquery-mobile-custom.js"></script> <!-- [YB 2012/02/27 We can use this file to modify the global defaults of jQuery Mobile] --> <!-- Mobiscroll plugin - DatePicker widget for mobiles --> <link href="plugins/mobiscroll/mobiscroll-1.5.3.min.css" rel="stylesheet" type="text/css" /> <script src="plugins/mobiscroll/mobiscroll-1.5.3.min.js" type="text/javascript"></script> <!-- Fidget plugins for additional touch gestures (e.g. pinch) --> <script src="plugins/fidget/jquery.fidget.beta.1.js" type="text/javascript"></script> <!-- PhoneGap 1.4.1 --> <script type="text/javascript" charset="utf-8" src="phonegap/phonegap-1.4.1.js"></script> <!-- Our stuff --> <link rel="stylesheet" href="index.css" /> <script type="text/javascript" charset="utf-8" src="coordinateSystems.js"></script> <script type="text/javascript" charset="utf-8" src="extents.js"></script> <script type="text/javascript" charset="utf-8" src="util.js"></script> <script type="text/javascript" charset="utf-8" src="index.js"></script> </head>
Are you executing your ArcGIS JS API code inside a function called by dojo.ready (or dojo.addOnLoad, they're the same)? dojo.ready waits for the DOM to load AND waits for all modules that you've dojo.require'd to load.
