So I am trying to combine a couple of samples together. The first thing I did was used this example to create a search on my point feature layer. It took some modification because the sample was on polygons and I am using points. So I had to use a SimpleMarkerSymbol. So basically the lines that are commented out were the ones updated. http://developers.arcgis.com/javascript/samples/find_map_datagrid/ function showResults(results) {
//This function works with an array of FindResult that the task returns
map.graphics.clear();
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
12,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_NULL,
new Color([0, 0, 0, 0.9]),
new Color([0, 0, 0, 0.5])
//---- Use this code if polygons ----///
// var symbol = new SimpleFillSymbol(
// SimpleFillSymbol.STYLE_SOLID,
// new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
// new Color([98, 194, 204, 0.5])
);I like zooming in using a button rather than zooming in on the row like this example.. http://developers.arcgis.com/javascript/samples/fl_zoomgrid/However, I cannot get it to work. The grid: <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
<thead>
<tr>
<th field="STOREID" formatter="makeZoomButton" width="40px">
<img alt="+" src="assets/images/i_zoomin.png" width="18" height="18"/>
</th>
<th field="STOREID" width="50px">ID</th>
<th field="STORENO" width="70px">Store No</th>
<th field="STORENAME" width="150px">Store Name</th>
<th field="ADDRESS" width="250px">Address</th>
<th field="SALES" width="50px">Sales</th>
<th field="GSF" width="50">GSF</th>
</tr>
</thead>
</table>
</div>
Here is the functions that it is calling. makeZoomButton seems to be working okay but the zoomRow continues to get an Line: 190Error: 'evt' is undefined. function zoomRow(id){
var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).STOREID;
var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
return ((graphic.attributes) && graphic.attributes.STOREID === clickedTaxLotId);
//CREATE THE POINT WITH THE SELECTED ROW
var center2 = [selectedTaxLot[0].geometry.getLongitude(), selectedTaxLot[0].geometry.getLatitude()];
//ZOOM LEVEL
var zoom2 = 15;
//CENTER AND ZOOM
map.centerAndZoom(center2, zoom2);
